Online Now [51]:
Visitors: 51
Today: 77550
Total: 105971500
Forums › The Car › 206 Problems › In urgent need of some help please??
connett2003
PostPosted: Mon Dec 19, 2011 4:23 pm Up
Hi guys its been a while but i changed a gearbox on a 2003 1.6 petrol citroen picasso (not a 206 i know) and all was well driven 25mile or so stopped and started back up fine... got home and then tried to start it again and it wont start, ive checked battery its fine when trying to start it the starter clicks but wont engage onto the flywheel any ideas or solutions would be greatly appreciated thanks, Mark
1998 Green/Black peugeot 206 GLX, black/green theme, gloss black bumpers, side strips, spoiler, eyebrows and ph2 boot strip cupra r splitter, black angels, smoothed bonnet, smooth badgless grill, euro plates, black fogs.
PostPosted: Mon Dec 19, 2011 4:37 pm Up
Have you fitted the gearbox right?
Manual or Auto?
connett2003
PostPosted: Mon Dec 19, 2011 4:48 pm Up
Yeah mate all plugs are in and bolts tight and its a manual mate.
PostPosted: Mon Dec 19, 2011 6:04 pm Up
Gearbox earth?
connett2003
PostPosted: Mon Dec 19, 2011 6:06 pm Up
There all on bud
PostPosted: Tue Dec 20, 2011 1:13 am Up
have you fitted a new clutch kit or you used the old ones??
PostPosted: Tue Dec 20, 2011 2:30 am Up
How did you check the battery?
It might be worth giving the connections a little clean and re-tightening them. If it still clicks after that, try jump starting.
If you're feeling brave in this weather, lie under the car and tap the starter gently with a hammer while someone turns the key. This will determine if it's a dicky starter motor or not. If this works, then whip off the starter and get a recon unit from an auto factors.
leigh_boy
PostPosted: Tue Dec 20, 2011 2:38 am Up
sounds like the solinoid on the starter has given up ( common on most cars) take that starter off, and start the car and see if the cog slides up the shaft.
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
connett2003
PostPosted: Tue Dec 20, 2011 3:04 am Up
Its a new clutch kit, tried tapping it with a hammer still nothing and the battery and terminals are like new. Il get it off and try start it guys cheers
connett2003
PostPosted: Tue Dec 20, 2011 6:21 am Up
It was the starter motor shooting out but not spinning thanks guys
PostPosted: Tue Dec 20, 2011 6:24 am Up
I've got a starter motor if you need one
leigh_boy
PostPosted: Tue Dec 20, 2011 8:34 am Up
thougth it might be Smile
*DEAD*206 Gti 138
