Latest: tc.206
Overall: 17147
Online Now [133]:
Visitors: 132
Today: 44997
Total: 116541408
Forums › The Car › 206 Problems › p0270 cylinder 4 injector problems
chris_loader
PostPosted: Tue Dec 27, 2011 6:22 am Up
this code has been coming up intermetintly for months now sometimes wont come up for months at a time but i have changed the injectors around and it only seems to bring up number 4 so would this be a wireing problem
chris
206cc 2.0 16v
PostPosted: Tue Dec 27, 2011 6:35 am Up
Injector number 4 is the TIMING BELT end Wink
Hope you changed the correct injector Laughing
chris_loader
PostPosted: Tue Dec 27, 2011 6:56 am Up
oh really i was told it was the other end opps
206cc 2.0 16v
chris_loader
well ill let you know when i have striped it down again lol
206cc 2.0 16v
PostPosted: Tue Dec 27, 2011 6:58 am Up
Number 1 is gearbox end on the TU lump.
Number 4 is timing belt end.
Your not the first & wont be the last to make this same mistake Rolling On The Floor Laughing
PostPosted: Tue Dec 27, 2011 7:08 am Up
While your there fix the leak from the windscreen washer jet, thats what normally causes injector 4 to fail Wink
chris_loader
PostPosted: Tue Dec 27, 2011 7:48 am Up
oh realli i dont think it is leaking and im used to my vw and audis as thats what i drive but want a 106 gti aswell
206cc 2.0 16v
PostPosted: Tue Dec 27, 2011 8:10 am Up
All Frenchare the opposite way
chris_loader
PostPosted: Tue Dec 27, 2011 8:12 am Up
i will remember that lol i will let you know how i get on and if it not good im off the the breakers tomorow to find a injector
206cc 2.0 16v
PostPosted: Tue Dec 27, 2011 12:32 pm Up
Mostly ruined now & also take some skill to drive Wink
Unless your a skilled driver a 106 GTI driven hard will be picking a hedge sooner or later Laughing
chris_loader
PostPosted: Tue Dec 27, 2011 1:11 pm Up
i see ill stick with my bora turbo ill finish the 206 tomorow and see if it is the injector if so ill go breakers and get one and the harnes for them
206cc 2.0 16v
PostPosted: Tue Dec 27, 2011 1:15 pm Up
106 is old school Peugeot chassis design, great to drive if you know what your doing BUT they can bite when you run out of talent.
Modern Peugeot chassis design like the 206 will just understeer safely when you get it wrong, 106 when you run out of talent you can end up with the backend trying to overtake the front Laughing
chris_loader
PostPosted: Tue Dec 27, 2011 1:24 pm Up
206 gti 180 then Smile
206cc 2.0 16v
PostPosted: Tue Dec 27, 2011 1:31 pm Up
There ok for the cheap prices you can pick them up for now.
chris_loader
PostPosted: Wed Dec 28, 2011 12:15 pm Up
right looks like that has sorted it i picked up a couple of injectors cheap and now from the usefull info about the cylinder numbers being backwards looks like its alive Smile
206cc 2.0 16v
