Latest: flipflap
Overall: 17140
Online Now [364]:
Visitors: 363
Today: 15121
Total: 113922496
Forums › The Car › 206 Problems › Daughters' 206
Daughters' 206
206NorthYorks
PostPosted: Mon Jan 02, 2012 4:22 pm Up
Hello folks,
First time on here, and it's to ask for help.
Recently her 1.1 206 over heated in traffic. I took it to Glews Garage near Goole. After a high bill the fault was diagnosed as corroded wiring, and radiator sensors, low and high speed.
Everything was done with the low speed sensor ordered.
Then yesterday, her engine management light came on and the sh*tty car started running on three cylinders!
I had a look and thought that some of the wiring was wet, maybe from the overheat and coolant from the expansion bottle.
Any ideas please before the Dads garage bill shoots up (again!)
mattievrs
PostPosted: Mon Jan 02, 2012 4:27 pm Up
head gasket gone? Thermostat bu66ered?
If its overheating and dropped to 3 cylinders id bet it h/g gone. Get it compression tested.
NO LONGER ACTIVE ON THE FORUM
PostPosted: Mon Jan 02, 2012 4:31 pm Up
is the thermostat working?
206NorthYorks
PostPosted: Mon Jan 02, 2012 4:32 pm Up
Thank's but I hope you're wrong!
The plugs seems to be the correct colour. I haven't got a compression tester, but yes it's worth a check.
Is corroded wiring, overheating, head gasgets regular on these things?
A Anderson
206NorthYorks
PostPosted: Mon Jan 02, 2012 4:34 pm Up
It dosen't seem to be over heating now the fan sensors have been changed. But as I mentioned, it's now running on three with the engine management light on Sad
A Anderson
PostPosted: Mon Jan 02, 2012 4:57 pm Up
I code read them for £20 + £0.60 a mile one way after 20 miles from S25.
Would be roughly £30 for me to come to you (based on typing Goole into Google)
sillyhilly
PostPosted: Mon Jan 02, 2012 6:13 pm Up
Get a compression tester kit. You can get them for around £10 in store.
Take off your coil pack, unscrew the spark plugs, screw in the compression test to Cylinder 1, record compression. Repeat for 2, 3 and 4.
Put in a small amount of oil in Cylinder 1, recheck the compression. Repeat for 2, 3 and 4.
Really, there was no need to take it to the garage and get a costly bill (out of interest, how much was this?) as you could have checked all of the necessary parts yourself cheaply and quickly.
Hi Mikey Smile
206NorthYorks
PostPosted: Thu Jan 05, 2012 4:47 pm Up
Sorry for the delay, been away from the comupter.
The daughter has booked the thing in to Glews Garage (again).
The hourly rate last time was £63.50!
It cost £167.50 for them to tell me that the rad fan sensors where knackered. So I dread the bill this time!
A Anderson
PostPosted: Thu Jan 05, 2012 4:53 pm Up
Pure LOL's
Guessing you have aircon, with the sensors at the front. They corroded like a chocolate tea pot melts.
Plus the headgasket has gone now too, oh and we charge at a main dealers £86.76 per hour for diagnostic work
You got raped
206NorthYorks
PostPosted: Fri Jan 06, 2012 1:47 pm Up
Addaz wrote:
Pure LOL's
You got raped
Wrong!
Knackered injector! Stupid French crap!!
£188 bill.
A Anderson
sillyhilly
PostPosted: Fri Jan 06, 2012 1:51 pm Up
Why take it back there once you've been slapped with that bill once before?
Fool me once...
Hi Mikey Smile
PostPosted: Fri Jan 06, 2012 2:19 pm Up
206NorthYorks wrote:
Addaz wrote:
Pure LOL's
You got raped
Wrong!
£188 bill.
I was talking about the first time, not the second bill. Effort levels and all that
Btw injectors second hand go for about £20 (all four and rail) and take about 20 minutes to fit by an untrained person
