Latest: sparrowdclxvi
Overall: 17139
Online Now [122]:
Visitors: 122
Today: 35806
Total: 113563170
Forums › The Car › 206 Problems › French piece of s***... help please!
Silvery206
PostPosted: Thu Jan 05, 2012 4:23 pm Up
Most likely the speedo unit.
Silvery 206
Lee wrote:
Plug the laptop in to see if it's reading the RPM Laughing
me don't know how to do this Sad erghhhh
PostPosted: Thu Jan 05, 2012 4:24 pm Up
Harry wrote:
Saxo has always done it, diagnoses equipment doesn't work with it so I checked all the fuses, replaced the cluster and it is still doing it.
Haven't got round to trying anything else yet
Speed sensor Whistle...
PostPosted: Thu Jan 05, 2012 4:25 pm Up
Are you in leeds?
If so, i'm heading north on the M1 tomorrow, if you meet me enroute, I'll quickly plug the laptop in.
Mike_XS
PostPosted: Thu Jan 05, 2012 4:30 pm Up
Could this be another problem you can add to the list you can blame on being so low? Smile
PostPosted: Thu Jan 05, 2012 4:31 pm Up
Lee wrote:
Are you in leeds?
no i'm not unfortunately
cheers though Thumb Up
PostPosted: Thu Jan 05, 2012 4:36 pm Up
If you have a latop - this www.ebay.co.uk/itm/ELM...1e6791bf32
Learnt a lot from Lee Rolling On The Floor Laughing
When I get round to it Wink
Starting with the easiest things first
PostPosted: Thu Jan 05, 2012 4:44 pm Up
Is that item acturaly any good Harry? Been looking for one like that, it's just had one for my Astra like that once and it didn't work.
PostPosted: Thu Jan 05, 2012 4:48 pm Up
Does the job, the guy I bought it off just threw a load of programs onto the disk so it took a while to get the right one working but it's good now it is.
Reads and clears codes, shows engine temp, revs, throttle position etc
Feel free to borrow mine if you want to test it before you pay out some cash for it.
AshH
PostPosted: Thu Jan 05, 2012 4:49 pm Up
Is it me or does it seem Adam wants the competition to be taken to the scrappy lol
Team - 180
Team - ATM!!!
PostPosted: Thu Jan 05, 2012 4:50 pm Up
Ben...china clone will be ok for scanning just don't do programming
www.ebay.co.uk/itm/VAU...932wt_1037
PostPosted: Thu Jan 05, 2012 4:54 pm Up
disconnected for 15 mins and reconnected, still the same... why can't the cluster be taken apart and repaired why does it have to be replaced all together ?
HDI90
PostPosted: Fri Jan 06, 2012 3:54 am Up
If you want to buy a just a new rev counter you can, also the speedo motor is the same as the rev counter motor
this happend to me last year so all i did was swap the speedo and rev counter around to find the fault
its the same as this one
vehicles.vivastreet.co...r/37076089
GTI 180
rick-gti
PostPosted: Fri Jan 06, 2012 4:07 am Up
this happened with my gti 138. replaced the cluster and still remained. i tried another cluster to make sure i hadnt got a dud and it worked fine. must be a common problem on these.
is your pug multi plex? mine isnt so cost me a fair bit for the clusters, think multi plex type are cheaper tho.
should find a set for £30 make sure they work Thumb Up
clio 197sport owner
sillyhilly
PostPosted: Fri Jan 06, 2012 5:54 am Up
Who really needs a rev counter?!
Hi Mikey Smile
Page 2 of 3
