Online Now [74]:
Visitors: 72
Members: 1
Today: 11341
Total: 116698140
Forums › The Car › 206 Problems › Removing & Installing 2001 206 GTI Indicator And Light Stalk
Lizard2010
PostPosted: Fri Jan 13, 2012 4:27 am Up
I have ordered a new Stalk.
Does anyone have any tips or hints.
To install the new one.
Is there anything to be disconnected before starting the job. Smile
Owner of a 2001 Peugeot 206 GTI 2.0 16v
PostPosted: Fri Jan 13, 2012 4:36 am Up
Make sure the BSI unit is shut down correctly first!
2 x torx 20 screws under the plastic coloumn trim to undo, top half of trim lifts off once the bottom half is removed.
Set front wheels dead straight!
Airbag is clipped on, flat blade screw driver needed, feel around the back of the wheel for slot in the bottom steering wheel spoke.
Screwdriver in & push the spring clip up, airbag should release, might take a few goes to get the hang of it.
Yellow locking clips hold the 2 x airbag connector plugs in, plugs are also colour coded so you cant mix them up.
Red spade connector is 1 half of horn wiring.
Black ring terminal on steering wheel is the other half, there is a grey connector on the com, thats the horn plug.
Undo torx bolt for steeringwheel a few turns, DON'T remove it yet!
Smack the back of the steering wheel with your hands till it pops free of the splines.
Now remove bolt, wheel.
Metal clamp on back of com, undo the bolt, unplug com connectors, 3 plastic clips, slide com unit off.
Unclip radio remote stalk & slide it out.
Refitting is reversal of removal.
Airbag connectors - make sure there fully in & seated before then pressing in the yellow locking clips!
Use thread lock on steering wheel bolt!
Reboot the BSI correctly.
PostPosted: Fri Jan 13, 2012 6:42 am Up
ld-automotive.com/down...column.pdf
PostPosted: Fri Jan 13, 2012 6:49 am Up
I need to replace the com on my 206 sooner or later, might even get round to writing a how to Laughing
Then again it would be pretty pointless as no sod uses the search Rolling Eyes
Lizard2010
PostPosted: Fri Jan 13, 2012 6:59 pm Up
MrBSI Thanks.
How do you Make sure the BSI unit is shut down correctly first!
Thanks Again Smile
Lizard2010
PostPosted: Fri Jan 13, 2012 7:03 pm Up
Lee wrote:
http://ld-automotive.com/downloads/Print%20-%20206%20-%20C5FG2AF1%20-%20Removing%20-%20refitting%20_%20Top-of-column.pdf
Thanks Lee Smile
PostPosted: Fri Jan 13, 2012 7:07 pm Up
206 Talk > Beginners Guide to a 206
Lizard2010
PostPosted: Sun Jan 15, 2012 1:58 am Up
Thanks lee.
I will pass onto mechanic when he does the job plus other work i need doing Smile
Lizard2010
PostPosted: Wed Feb 01, 2012 4:12 am Up
Thanks to Mr BSI & Lee.
Indicator stalk all fixed now.
Mechanic fitted today.
It certainly work all the time now.
