Latest: Worthy967
Overall: 17143
Online Now [243]:
Visitors: 242
Today: 44139
Total: 115819026
Forums › The Car › 206 Problems › Anti Pollution Fault
karimali831
PostPosted: Sat Jan 14, 2012 7:02 pm Up
Very doubt this is fault because I have had this ever since I replaced the F15 I blown so I drove to petrol garage without any instruments working, replaced fuse and now got the instruments/MDF working fine but the anti pollution illuminates and shows on MFD, I'm assuming it is because I drove without instruments working?
I tried resetting BSI which had no effect also disconnected battery for 10 minutes and also no effect. Could there be anti pollution fault or is there correct procedure to get rid of it?
Thanks to all.
206 GTI 180
PostPosted: Sat Jan 14, 2012 7:09 pm Up
get the code scan
AshH
PostPosted: Sun Jan 15, 2012 4:34 am Up
Been covered plenty of times, some with good results some with bad! Get it code read and ask someone like Mr BSI if he can point you in the direction of what the code is! Anti Polution Fault can mean alot mate (n)
Team - 180
Team - ATM!!!
HDI90
PostPosted: Sun Jan 15, 2012 4:48 am Up
I ran mine low on diesel and it came on then went off after i refilled up. it can mean 1001 things
GTI 180
karimali831
PostPosted: Sun Jan 15, 2012 5:29 am Up
This morning the fault disappeared. Smile
Because I driven without any instruments, the fault illuminates so probably must be driven with instruments working to distinguish the fault.
206 GTI 180
PostPosted: Sun Jan 15, 2012 6:47 am Up
I was going to say, would probably dissapear within 50 miles of driving.
