Online Now [313]:
Visitors: 312
Today: 18702
Total: 105282130
Forums › The Car › 206 Problems › Airbag fault
Airbag fault
karimali831
PostPosted: Fri Jan 20, 2012 7:28 pm Up
Have started engine and on dash it says "Passenger airbag deactivated" followed by a *beep* "Airbag Fault". I looked at manual and it mentions only to contact Peugeot dealer. Not sure what checks to do to rectify this, the airbag pass is on also.
Anyone had this issue?
206 GTI 180
ukskater01
PostPosted: Sat Jan 21, 2012 2:43 am Up
Where do you live? I can and a couple of others on here code read the airbag ecu to see what the fault is. Or you can buy a cheap code reader. Don't go to the dealer as they will rip you off. My 206's passenger airbag had an open circuit, under the passenger seat carpet there were two plugs(I think) just pushed them together.
PostPosted: Sat Jan 21, 2012 4:44 am Up
Y
ukskater01 wrote:
Where do you live? I can and a couple [marq=right]of others on here code read the airbag ecu to see what the fault is. Or you can buy a cheap code reader. Don't go to the dealer as they will rip you off. My 206's passenger airbag had an open circuit, under the passenger seat carpet there were two plugs(I think) just pushed them together.
Wrong on two accounts there.
It's either the airbag or the switch, cheap wont read these faults
ukskater01
PostPosted: Sat Jan 21, 2012 5:22 am Up
Ah, forgot the cheap ones only do most engine faults. Smile
karimali831
PostPosted: Sat Jan 21, 2012 5:40 am Up
Switch is on although it says it is deactivated, could this be fuse or anything obvious? Not sure why this error came up so sudden.
206 GTI 180
Lecktorious
PostPosted: Sat Jan 21, 2012 5:44 am Up
Trade Rating: +59
Won't be the fuse.
Get the codes read, you're p**sing in the wind otherwise.
'98 Nile Blue 306 GTi 6
skard
PostPosted: Sat Jan 21, 2012 5:49 am Up
show off Wink
PostPosted: Sat Jan 21, 2012 5:55 am Up
checked the wires on the back of the switch
ECU needs scanning, it will pinpoint the exact fault and give you an idea of how to repair it Smile
karimali831
PostPosted: Sat Jan 21, 2012 6:23 am Up
The thick green/yellow, thick yellow and thin grey wires from driver A pillar has all been spliced and this airbag fault came up as soon after I was re-wiring them. Could this of caused airbag fault, surely no?
206 GTI 180
PostPosted: Sat Jan 21, 2012 6:25 am Up
If this is the 180 then it will have curtain airbags & guess where the wires run Wink
karimali831
PostPosted: Sat Jan 21, 2012 6:31 am Up
Must of messed up again.. Evil or Very Mad
From installing headunit to anti pollution fault and installing rear light to airbag fault. Complex of multi-plex!
206 GTI 180
PostPosted: Sat Jan 21, 2012 6:34 am Up
Nothing wrong with multiplex wiring.
Green & yellow is going to be an earth.
What are the wire numbers for the cables that have been spliced?
Sure you havent knocked a plug for the curtain airbag?
PostPosted: Sat Jan 21, 2012 6:44 am Up
Don't touch what you don't know anything about.
ukskater01
PostPosted: Sat Jan 21, 2012 7:09 am Up
skard wrote:
show off Wink
Lol! Works perfectly, thanks again Smile
PostPosted: Sat Jan 21, 2012 8:04 am Up
ukskater01 wrote:
skard wrote:
show off Wink
You need to learn how to use it properly before you wreck a ECU Wink
Practice on your own car before
