Latest: morgan20
Overall: 17135
Online Now [346]:
Visitors: 345
Today: 36831
Total: 110588986
Forums › The Car › 206 Problems › Knocking noise when not accelerating/braking
ARRAN
PostPosted: Sat Jan 21, 2012 7:06 am Up
I have a knocking noise coming from the front end, but it only happens when I stop accelerating or start braking. I have a 2003 1.4 8v Quiksilver. Its done 116k. Cheers Smile
See my project here.
MrZiggerz
PostPosted: Sat Jan 21, 2012 7:19 am Up
Checked the wheels are done up?
ARRAN
PostPosted: Sat Jan 21, 2012 7:29 am Up
I will check that in a bit, thanks
D4NTP
More than likely an engine mount that busted.
PostPosted: Sat Jan 21, 2012 7:32 am Up
Bit of a vague description. Low down? High up? Left? Right? Can you feel it through the floor???
ARRAN
PostPosted: Sat Jan 21, 2012 7:40 am Up
Seems to be more so in a straight line. And not really, no. Can hear it more than feel it.
PostPosted: Sat Jan 21, 2012 8:01 am Up
straight or cornering?
it the road flat?
ARRAN
PostPosted: Sat Jan 21, 2012 8:05 am Up
flat road, mainly in a straight line when deaccelerating and braking
ARRAN
PostPosted: Sat Jan 21, 2012 8:23 am Up
just tightened all the wheel nuts, didnt make any difference
craigdmjv
PostPosted: Sat Jan 21, 2012 10:01 am Up
ive got a wobble that i can feel all the time feels like its from the front wheels and sort of effects the steering too, mines done 127k
Andy180
PostPosted: Sat Jan 21, 2012 5:13 pm Up
C.V joint, driveshafts and balljoints are all things u could check might be one of them engine mount was a good shout by D4NTP as well.
GTI 180
ARRAN
PostPosted: Sun Jan 22, 2012 7:02 am Up
My dad thinks it sounds like something in the gearbox, like something is stuggling under engine braking. It only knocks at low speeds say 10mph, but anything over that it sounds more like a whining noise, kinda like a bearing.
PostPosted: Sun Jan 22, 2012 9:58 am Up
Thumbs Up
Sounding like another MA gearbox about to bite the dust Rolling On The Floor Laughing
ARRAN
PostPosted: Sun Jan 22, 2012 10:01 am Up
Sad
