Posted: Sat Jan 28, 2012 4:45 pm |
my second gear can be a bit snatchy sometimes ,could changing the gear oil make it better.its a 206 1.1
if so what oil could i use
thanks.or maybe adjusting the link rods.
Posted: Sat Jan 28, 2012 4:47 pm |
Posted: Sun Jan 29, 2012 3:43 am |
I was thinking of useing castol syntrax would this be better.
Posted: Sun Jan 29, 2012 5:11 am |
If you aren't going to listen, then why ask?
Posted: Sun Jan 29, 2012 7:44 am |
only use 75w/80
no matter what brand. only use 75w80, if you want fancy stuff get miller or Motul, they are less than a tenner for 1 litre.
not other like 75w/90; 70w/75, 75w/140 etc.....
the PSA synchro is just picky on oil
Posted: Sun Jan 29, 2012 7:47 am |
Correct oil is less then £8 for 2 litres from any Peugeot / Citroen main dealer.
Not that anyone bothers to take any notice anymore
Posted: Sun Jan 29, 2012 7:48 am |
| MrBSI wrote: |
Not that anyone bothers to take any notice anymore  |
we should blame halford as they only got 75w90 oil in stock
Posted: Sun Jan 29, 2012 7:50 am |
| Seabook wrote: |
| MrBSI wrote: |
we should blame halford as they only got 75w90 oil in stock  |
I've got 200 litres of gearbox oil in stock at work, i've no idea what spec it is, ill have a look at the barrel tomorrow
Posted: Sun Jan 29, 2012 7:51 am |
| MrBSI wrote: |
| Seabook wrote: |
| MrBSI wrote: |
I've got 200 litres of gearbox oil in stock at work, i've no idea what spec it is, ill have a look at the barrel tomorrow  |
i just love to nick stuff at work
i think i have enter the wrong section...
Posted: Sun Jan 29, 2012 7:52 am |
Halfords do a 75/80 gearbox oil.
Posted: Sun Jan 29, 2012 7:53 am |
I've already got enough oil borrowed from old job to keep the 206 in oil changes for a good few years yet
As for gearbox oil, that can wait till clutch change time.
Posted: Sun Jan 29, 2012 7:55 am |
| Edward wrote: |
| Halfords do a 75/80 gearbox oil. |
halford own brand?
never check their own brand oil.
Posted: Sun Jan 29, 2012 8:00 am |
Yes it's Halfords own which is perfectly adequate.
Posted: Sun Jan 29, 2012 8:02 am |
| Edward wrote: |
| Yes it's Halfords own which is perfectly adequate. |
I'd much rather pay £7.88 at any Peugeot / Citroen main dealer for 2 litres.
