Latest: eltel666
Overall: 17146
Online Now [50]:
Visitors: 49
Today: 21307
Total: 116243991
Forums › The Car › 206 Problems › Headlight bulbs
Headlight bulbs
206Mike
PostPosted: Sun Jan 29, 2012 8:17 am Up
Just a quick one, blown the bulb for main beam, best brand to replace with
Also is there any particular sizes for the main beam bulbs and sidelight bulbs?
Any help much appreciated dudes
+8 Pos feedback Smile
PostPosted: Sun Jan 29, 2012 8:20 am Up
you could of seached this as this question has been asked so many time before.
Headlight bulbs will be H7 on yours and you will have 4, 2 in each headlight. Best brand to go for is Philips Xtreme and if you are upgrading them you will need to replace them in pairs.
Sidelights will be 501 and most people use LED SMD bulbs but dont buy too cheap as they will not last.
iainlovatt
PostPosted: Sun Jan 29, 2012 8:21 am Up
i have been told that philips are the best, the nightbreakers
(My Garage)
PostPosted: Sun Jan 29, 2012 8:26 am Up
Philips dont make nightbreakers.
Philips X-treme +100% are the bulbs you want.
206Mike
PostPosted: Sun Jan 29, 2012 8:50 am Up
Cheers for the help dudes, apologies for not using the search button Sad
PostPosted: Sun Jan 29, 2012 9:37 am Up
If you buy the Philips or the Osram, put them in your dipped beam and move your dipped beam bulbs into your main beam. Might as well have the best light output for the lights you use most often.
As you seem inexperienced in your knowledge of headlight bulbs, one bit of advice. Don't touch the glass with your fingers. The oil in your hands can make the bulbs fail prematurely.
206Mike
PostPosted: Sun Jan 29, 2012 11:36 am Up
Haha no worries, made sure not to touch the bulbs. Replaced a few whilst i was at it. Love you dudes Smile
