Online Now [52]:
Visitors: 51
Today: 7764
Total: 106137504
Forums › The Car › 206 Problems › Main beam problem
Main beam problem
eggy6832
PostPosted: Sat Feb 04, 2012 4:50 am Up
A while back my headlight connectors were melting due to the idiot I brought the car off using bulbs that were for off road use. So I bought sum new h7 connectors of eBay and tried replacing them as a straight swap however my bulbs do not work.
The original off road bulbs were working fine but then whenever I went over a bump they go off but could've wiggled back into place and work again this Is when I notice the connectors and decided to replace them. Bunks I have no lights the full beam are still Woking fine justno headlights?
What fuses/relays should I check to make sure they working?
Any help greatly appreciated
owner of a 206 gti
lmilligan
PostPosted: Sat Feb 04, 2012 6:46 am Up
Look in your car handbook.
PostPosted: Sat Feb 04, 2012 6:56 am Up
Check your fuses, table of them can be found in your owners manuel. Have you replaced the damaged wiring?
eggy6832
PostPosted: Sat Feb 04, 2012 11:49 am Up
I have replaced wiring but doesn't work
owner of a 206 gti
