Latest: Stu-mill
Overall: 17131
Online Now [299]:
Visitors: 298
Today: 21551
Total: 104830411
Forums › The Car › 206 Talk › suspention
suspention
wezyb89
PostPosted: Wed Feb 08, 2012 12:31 pm Up
i just changed the standard suspention on my 206 to biltiens and no the car shakes my mate told me i need to get the wheels realined is this true help plz
w.byrne
PostPosted: Wed Feb 08, 2012 12:39 pm Up
Gotta be honest, people like basic punctuation on here. You will recieve little help and mostly abuse otherwise.
I'm struggling to read what you put. Are you saying your car is shaking after you have lowered it?
wezyb89
PostPosted: Wed Feb 08, 2012 12:42 pm Up
sorry mate am on ma phone touch screen, yes i lowered the front and changed the shockers put it all back together and now it shakes when am doing about 50mph i have got to lower the back yet but am just seeing weather its my fault or because i moved things while changing suspension.
w.byrne
PostPosted: Wed Feb 08, 2012 1:09 pm Up
If you've done everything properly the tracking might need attention but lowering wouldn't cause vibration even with the changes in geometry.
Did it not vibrate before?
wezyb89
PostPosted: Wed Feb 08, 2012 1:13 pm Up
no didn't vibrate before, am quite worried. only had the car 4 months
w.byrne
wezyb89
PostPosted: Wed Feb 08, 2012 1:16 pm Up
when driving at 50mph, you can hear the shaking (sounds like the steering rack or column) but am not 100%
w.byrne
PostPosted: Wed Feb 08, 2012 1:48 pm Up
did you put the wheels back on properly?
wezyb89
PostPosted: Wed Feb 08, 2012 1:52 pm Up
i think so i will re check them tho.
w.byrne
