Latest: Beduff1977
Overall: 17134
Online Now [368]:
Visitors: 367
Today: 20010
Total: 107200934
Forums › The Car › 206 Problems › Quick response needed!
pnut_man
PostPosted: Fri Feb 17, 2012 9:16 am Up
what is this part and what does it do?? i was changing my discs on my gti and this was cracked.
this is where it came from
a quick respones is needed as it needs fixing asap. cheers!!
PostPosted: Fri Feb 17, 2012 9:18 am Up
Its an ABS ring from the driveshaft.
pnut_man
PostPosted: Fri Feb 17, 2012 9:24 am Up
can i drive my car without it?
PostPosted: Fri Feb 17, 2012 9:25 am Up
Yes BUT the ABS system wont work & it will fail the MOT.
You can get a new ABS ring & get it fitted OR replace the complete drive shaft.
Cracked ABS rings are a common 206 GTI problem Wink
pnut_man
PostPosted: Fri Feb 17, 2012 9:27 am Up
ahh. is it a simple job to fix?
PostPosted: Fri Feb 17, 2012 9:31 am Up
That depends on your skills & tools.
You need to remove the driveshaft from the hub to get the new ABS ring fitted on.
A new ABS ring is pretty cheap, someone did post a link before on here to a supplier.
If your handy with the spanners then its a pretty cheap fix.
Big_Rich180
PostPosted: Fri Feb 17, 2012 9:50 am Up
This should help.
www.reluctorrings.com/
pnut_man
PostPosted: Fri Feb 17, 2012 11:09 am Up
Cheers. ill be getting them from lt motors i think, only £12.
