Latest: tbafonso
Overall: 17130
Online Now [126]:
Visitors: 125
Today: 19692
Total: 103755506
Forums › The Car › 206 Problems › 206 gear box problem
dunny1987
PostPosted: Fri Feb 24, 2012 6:59 am Up
hi all. just purchased a 206 xsi 2002. which needs a gearbox. im struggling to find 1 so im wondering if a 307 1.6 gearbox will fit??
or a 307 hdi 1.6 box will fit as there seems to be alot of these on ebay.
any help much appreciated.
thanks
tom
The old moto "flat out or f*ck all" works well in a 206 with a faulty air pressure sensor haha Very Happy
Steve180
PostPosted: Fri Feb 24, 2012 7:08 am Up
If the 307 1.6 gearbox is a BE4 or MEC type, the internals will be the same but the housing will probably be different. I've looked on ServiceBox for you and there aren't any specs listed but the part numbers don't cross over against each other leading me to suspect that they won't fit.
2004 206 GTi 180: 207.9BHP, 183.1 ft/lbs
dunny1987
PostPosted: Fri Feb 24, 2012 7:13 am Up
bugger. so not even the petrol 307 box will fit then?
does anyone know a pug breakers who might have 1??
dunny1987
PostPosted: Sun Feb 26, 2012 3:07 pm Up
hello again, a friend has given me a 106 gti box out of a x reg and told me to swap the bell housing so i can match it to the engine and still have the hydraulic clutch????? does it work??
thanks again.
Dunny
PostPosted: Sun Feb 26, 2012 3:15 pm Up
yes it will work.
but that is a lot of work....
dunny1987
PostPosted: Sun Feb 26, 2012 3:36 pm Up
fantastic Very Happy i dont mind some extra hours i can not find a 206 xsi box for a realistic price, cheapest is £240 + £60 delivery Surprised
the gti box is free so its just strip 'n' swap now lol.
is there anything i sshould be aware of in advance? extra bits? seals or stuff need replacing while its out??
PostPosted: Sun Feb 26, 2012 3:39 pm Up
always worth to replace the drive shaft oil seal.
i am surprise it cost that much for MA box. i pick up one BE box the other day cost me less than 200 quid delivered
dunny1987
PostPosted: Sun Feb 26, 2012 3:44 pm Up
lol just as i wrote that my mrs just found 1 on ebay out of a 206cc for £125 and its already got hydro clutch. how was that for timing
PostPosted: Sun Feb 26, 2012 4:32 pm Up
that price was about right.
MA box is quite common
dunny1987
PostPosted: Sun May 20, 2012 2:40 pm Up
anyone heard of a 106 gti engine being put into a 106??? wats involved
D4NTP
PostPosted: Sun May 20, 2012 2:49 pm Up
Peugeot did this quite alot when building the 106. they would, in nearly all cases fit a 106 engine into a 106..... Now a crazy idea would be to put a 106gti engine in a 206.....
