Online Now [127]:
Visitors: 126
Today: 33461
Total: 139042373
Forums › The Car › 206 Talk › Lambda Seal?
Lambda Seal?
PostPosted: Mon Feb 27, 2012 4:56 pm Up
I've got to fit a new catalytic converter on the weekend, and need to swap the lambda sensors. Do i need to add any type of sealing product to them, or just screw them in. Also the the sensors are coming from a 180 cat to my 138 cat, will they be ok?
Dan-
PostPosted: Mon Feb 27, 2012 5:57 pm Up
the sealing ring should be okay on them i will have a look to see if the 180 and 138 uses the same sensors for you
Dan-
PostPosted: Mon Feb 27, 2012 6:05 pm Up
looking on service box it would appear the 138 with a motorised throttle bodies share the same lambda sensors with the 180, But I'm unsure weather all the 138 were built with motorised throttle bodies or not sorry
PostPosted: Tue Feb 28, 2012 1:37 am Up
Don't add anything apart from the metal sealing ring or it can poison the λ-sensor.
PostPosted: Tue Feb 28, 2012 1:46 am Up
They should all be the same fitting.
PostPosted: Tue Feb 28, 2012 7:28 am Up
Didn't even think to check service box. Mine has a motorised throttle, will probably get this done tomorrow. I'll do a how to if I get the chance. Not a bad job, just tight! Will give all the clamps a good soak tonight.
Dan-
PostPosted: Tue Feb 28, 2012 8:22 am Up
Yeah its a reletivly simple job made easier if you have drive on ramp Smile didn't take me long, would advise soaking them makes it abit quicker to undo, also a quick tip on getting the exhaust clamps off is to use another bolt and unwind the clamp so it open up enough to separate the sections! Will get a pic later for you of what I mean,
