Latest: Beduff1977
Overall: 17134
Online Now [1105]:
Visitors: 1104
Today: 169374
Total: 107570996
Forums › The Car › 206 Problems › Headlights URGENT!
Headlights URGENT!
bseedhouse
PostPosted: Sun Mar 04, 2012 1:52 pm Up
so I changed my headlight bulbs to some nice new ones and as I did this the passenger side went fine! but when I was changing the drivers side both lights stopped working! there seems to be three some loose connections and now neither main beam lights are working any advice!!
Benji\'
kurosagi01
PostPosted: Sun Mar 04, 2012 1:59 pm Up
You might of blown the fuses to power your bulbs,this what happened to me before i couldn't use the driver side main beam properly in my angels.
Your car manual should indicate which fuse box you need access whether its under your bonnet next to the battery or under steering wheel. Depending on the year of your car.
bseedhouse
PostPosted: Sun Mar 04, 2012 2:03 pm Up
its a 2002 lx? none of the fuses are blown i dont think i did check!
Benji\'
Lewis
PostPosted: Sun Mar 04, 2012 2:56 pm Up
you should have disconnected the battery before attacking main bulbs! try fuses, if not you could have bigger problems
Tivoli LX 1.1
Black GTI 180
White VXR Burg
kurosagi01
PostPosted: Sun Mar 04, 2012 3:09 pm Up
Your car should be multi-plex then so check under the bonnet the fuse box next to the battery and check these numbers they be numbered:
F9......15A........Left dipped beam.
F10....15A........Right dipped beam.
F11....10A........Left high beam.
F12....10A........Right high beam.
If the fuse inside snapped off then you will need replace them,if all of them are fine then could be you blown all your bulbs or you might have bigger problems.
bseedhouse
PostPosted: Tue Mar 06, 2012 3:01 pm Up
None of the fuses were broken and it seemed to almost fix itself yesterday however! my battery died today would this stop my main beam working?
Benji\'
