Latest: Beduff1977
Overall: 17134
Online Now [721]:
Visitors: 721
Today: 222800
Total: 107882821
Forums › The Car › 206 Problems › ABS warning light
ABS warning light
egouder
PostPosted: Sun Mar 25, 2012 8:12 am Up
Ok, I have this problem,
Today I cleaned the engine using a power wash and after that The Abs waring light turned on... I dont think that I actually have problems in my abs but what can I do to switch it off? Where is the abs sensor? thanks
btw mine is 1999 1.4l petrol, with front disc breaks.
PostPosted: Sun Mar 25, 2012 8:30 am Up
Did you power wash the engine? If so, take more care next time. I wouldnt worry about the light, has happened to me a few times, just drive it around a few times and the light will dissapear.
Unless you have actually done something!
egouder
PostPosted: Sun Mar 25, 2012 11:37 am Up
And I noticed that the warning light (ABS) only switch on with the hand break.
While driving it turns off immediately.
Does this mean that my ABS system is not working properly? Or it is just a sensor fault?
Thankyou
egouder
PostPosted: Mon Mar 26, 2012 6:44 am Up
CAn anyone give me some more information regarding this problem?
THe light only turns on when I have the hand break, and when I press the break with the hand break it switches off.
Thankyou
ej2_sir
PostPosted: Mon Mar 26, 2012 8:03 am Up
If it were me I'd start by disconnecting battery (follow the correct process) then go round all sensors in the engine bay disconnecting and give them a good spray with water repellent (wd40) and a quick blast of electric contact cleaner. Then reboot bsi and see if it has cleared. Pressure washing engine bays on modern cars is not clever really with all the electrics
2002 206 2.0hdi
egouder
PostPosted: Wed Mar 28, 2012 3:14 am Up
Ok, just to let you know that the light no longer comes on,
Thankyou all for your help, I will not power wash my engine bay again although it came out great hehe.
