Latest: S2cgm
Overall: 17178
Online Now [118]:
Visitors: 116
Bots: 2
Today: 71769
Total: 137602528
Forums › The Car › 206 Problems › GTI 180 Loss of power
Jammie_1989
PostPosted: Sat Apr 07, 2012 10:19 am Up
Was just out in my car and been driving like a nun for past day or so. Joined a motorway slip road put the pedal down and not much happened. It was seriously under powered. Got off the motorway and pulled over, restarted the engine and all was well again Surprised Anybody else had this issue as couldn't find anything on here or google. Is anything on its way out or was it just throwing a wobbler. Its under warranty for another 2 1/2 months so if something needs fixing will get it done.
206 gti 180
Dan-
PostPosted: Sat Apr 07, 2012 10:22 am Up
might be your vvt solenoid, far as i know it just needs removing and cleaning with carb cleaner, 1 sign is that the cars feels like a 1.1
Jammie_1989
PostPosted: Sat Apr 07, 2012 10:24 am Up
Yeah definately but would say more like a 1.4 as it moved a little. Any idea where the vvt solenoid is? have some carb cleaner in the garage from my old motorbike Smile
206 gti 180
Dan-
PostPosted: Sat Apr 07, 2012 10:25 am Up
will have a quick look for ya I've seen it somewhere on here Razz
Dan-
PostPosted: Sat Apr 07, 2012 10:30 am Up
i194.photobucket.com/a...mabove.jpg
the vvti solenoid is the sensor on the right hand side of the coil pack, (looking at that pic) its actually on the left looking at the engine, its held in with a allen key and just pulls out, but be carful not to drop when its out as its very delicate and rather pricey i think
Jammie_1989
PostPosted: Sat Apr 07, 2012 10:32 am Up
Dan- wrote:
http://i194.photobucket.com/albums/z44/kieronpunto/180enginefromabove.jpg
Thanks for the help appreciate it Very Happy will give it a clean 206info.co.uk
206 gti 180
Dan-
PostPosted: Sat Apr 07, 2012 11:02 am Up
no worries, also while your at it might swell clean the mass air meter, it only bolts into the throttle body, 10mm socket i think, access is very tight and you might drop the bolt but its just falls out under the car Very Happy
Jammie_1989
PostPosted: Thu Apr 12, 2012 1:13 pm Up
Think my carb cleaner has turned up as turns out I didnt have any so ordered some off ebay Smile Will give this a go at weekend hopefully will also sort out why it feels underpowered low down in the rev range. I know its high revving my my mums 1.4 206 has more urgency low down in second gear Confused
206 gti 180
donkeyding
PostPosted: Thu Apr 12, 2012 4:23 pm Up
Had a similar issue wih my 138 pal
Loss of power and warnin light. After replacing ALL the sensors on the engine including icv it turned out to be the cat had collapsed!!!
Just another thought pal. Worth checking!!
Cheers
Dave
Jammie_1989
PostPosted: Sun Apr 15, 2012 3:55 am Up
Gave it a good blast with the carb cleaner and seems to drive smoother and now picks up quicker lower in the revs. Just need to find the ICV now so its not rough at idle.
206 gti 180
Dan-
PostPosted: Sun Apr 15, 2012 4:01 am Up
hey at least your getting somewhere now Smile and btw the 180 doesn't have a removable icv its an electronic throttle body so the ivc not cleanable/removable
Jammie_1989
PostPosted: Mon Apr 16, 2012 5:51 am Up
Ah no problem, will try find the Mas air thingy and see if that does anything Smile
206 gti 180
Pugti6
PostPosted: Tue May 21, 2013 1:14 pm Up
I know this is an old post. Mine had these symptoms this morning. I was going up the road then power just dropped off. I was just wondering if anyone had a guide to cleaning the VVTi solenoid?
Did the problem stay solved? Or is it worth getting a new one?
Thanks you in advance for your advice
Big_Rich180
PostPosted: Tue May 21, 2013 1:38 pm Up
www.206info.co.uk/Foru...art=0.html
PostPosted: Tue May 21, 2013 2:01 pm Up
Hope you aren't still looking for it as there isn't one fitted!
