Online Now [605]:
Visitors: 604
Today: 24582
Total: 106154245
Forums › The Car › 206 Talk › Super Unleaded Q
Super Unleaded Q
PoppyChild
PostPosted: Tue Apr 17, 2012 3:25 am Up
I have a 206 LX auto and it's started being quite 'juddery' when I first set off (actually not when I set off forwards, only if I straight away do a 3 point turn) a friend said it sounds like a petrol block and I should chuck some cleaner in there, but I've read that using super unleaded will keep it clean. So I just wanted to check with you guys whether that's true? about it cleaning/keeping it clean, I don't really want to go putting things that aren't petrol into my petrol tank.. my OCD just wont allow it lol
seriously?
PostPosted: Tue Apr 17, 2012 3:29 am Up
simply changing the fuel filter might be a cheap and easy start.
Big_Rich180
PostPosted: Tue Apr 17, 2012 3:30 am Up
Super does have cleaning agents in it but I would suggest you get some one competent to check your car over as it could be a few things.
PoppyChild
Is that easy (aka requires no skill?)
seriously?
PostPosted: Tue Apr 17, 2012 5:41 am Up
PoppyChild wrote:
I have a 206 LX auto and it's started being quite 'juddery' when I first set off (actually not when I set off forwards, only if I straight away do a 3 point turn) a friend said it sounds like a petrol blockl
If its only 'juddery' when doing a '3 point turn', it sounds more like a clutch, drive shaft, or steering problem to me rather than a fuelling issue.
D4NTP
PostPosted: Tue Apr 17, 2012 5:57 am Up
It sounds more gearbox related with it being an auto. my auto box used to be a bit slow when cold and would cause the revs to dip pretty low when selecting reverse when the car was first started. Has the gearbox oil been checked/changed?
PoppyChild
PostPosted: Tue Apr 17, 2012 7:34 am Up
It's not every time, generally just in the morning, I can do the turn 3 or 4 times a day after that and it's fine (live in a small cul-de-sac I don't just go round randomly changing direction).
Not since I've had it unless that's covered under the very generic 'check all fluid levels' on a service.
Was having a look on the problems board and someone mentioned an MAP sensor fault which sounds similar.. so I'll just get him looked at by someone who has a clue.
Thanks for the replies Very Happy
seriously?
