Posted: Thu Apr 19, 2012 1:27 pm |
A new battery has been fitted last January so it shouldn't be this, the car has been having slow starts about 20% of the time and this morning the battery was completely flat, no central locking or lights working. They were not on at the time, all electronics turned off. Used my other motor to jump start it but on my return from work another slow start and I can only imagine the battery dying again tomorrow morning? I can only think the car needs a new alternator?
Posted: Thu Apr 19, 2012 1:28 pm |
get a multimeter and have a check?
Posted: Thu Apr 19, 2012 1:30 pm |
when runnning the reading should be around 14 when turned of it should be around 12
Posted: Thu Apr 19, 2012 1:37 pm |
Sounds like the alternator, but check the battery terminals are free of corrosion & that there's a good earth. Then get the alternator checked before buying a new one just to be sure.
Posted: Thu Apr 19, 2012 2:46 pm |
Thanks all, I'll get it checked out tomorrow..
Posted: Mon Apr 23, 2012 8:56 am |
the altnerator is good.. the battery is good... now the battery has gone flat again and the car alarm keeps going off and on. What else should I be checking?
Posted: Mon Apr 23, 2012 9:25 am |
Bad earth? Something left on thats draining the battery?
Posted: Mon Apr 23, 2012 11:09 am |
Grr it was stereo all along, both red and yellow are on permanent live and both must be connected for stereo to turn on, thought it would turn off when BSI deactivates, I'm sure it did anyway... I am using PC99-X44 any thoughts to why red and yellow are both live and not either is the ignition?
Posted: Mon Apr 23, 2012 11:49 am |
One of them turns off with the bsi cant remember which one.
