Latest: Beduff1977
Overall: 17134
Online Now [2268]:
Visitors: 2267
Today: 333495
Total: 110497875
Forums › The Car › 206 Problems › Emergency help needed please
gaffa786
PostPosted: Fri Apr 20, 2012 1:05 pm Up
I just had 3 new tired put on my car wel part worn. I just got onto the motorway and when id get of the gas ghe car turns n when i break it turns to the left bit scary with it turning it self so i had to quikly get of the motorway n park up. In manchester any ideas please i realy need to get to birmingham tonight
Stigter
PostPosted: Fri Apr 20, 2012 1:13 pm Up
You checked tyre pressures?
Can\'t be blank
gaffa786
PostPosted: Fri Apr 20, 2012 1:14 pm Up
Yh i jus set them both to 32 just before i left
Stigter
PostPosted: Fri Apr 20, 2012 1:15 pm Up
All the correct sizes?
Can\'t be blank
jayz206gti
PostPosted: Fri Apr 20, 2012 1:22 pm Up
Were they balanced?
Upgraded from 138 to 180
gaffa786
PostPosted: Fri Apr 20, 2012 1:24 pm Up
Yeah he balanced them on a machine
anton1989
PostPosted: Fri Apr 20, 2012 1:29 pm Up
Trade Rating: +16
sounds like tracking?
Stigter
wheels all been torqued up? I would call the aa to check before moving the car.
Can\'t be blank
gaffa786
PostPosted: Fri Apr 20, 2012 1:36 pm Up
Sorry dont no what torqued is and im not a member with any company aa or rac would they come to check still if i call ?
Stigter
PostPosted: Fri Apr 20, 2012 1:44 pm Up
I think they would - but they may apply a fee.
Can\'t be blank
PostPosted: Fri Apr 20, 2012 1:47 pm Up
they will, but who knows how much are they going to charge you.
can't believe people don't even have basic cover
gaffa786
Thanks il try now
PostPosted: Fri Apr 20, 2012 1:49 pm Up
Did they not teach English when you went to school?
Stigter
PostPosted: Fri Apr 20, 2012 1:59 pm Up
guessing as he is out and about - its sent from his phone.
Can\'t be blank
anton1989
Trade Rating: +16
its only £5 a month if that.
but then again look how much it is to get insured these day, im getting quotes of £3000 on a 1.1!
