Posted: Fri Apr 20, 2012 1:05 pm |
I just had 3 new tired put on my car wel part worn. I just got onto the motorway and when id get of the gas ghe car turns n when i break it turns to the left bit scary with it turning it self so i had to quikly get of the motorway n park up. In manchester any ideas please i realy need to get to birmingham tonight
| | ![](images/spacer.gif) |
Posted: Fri Apr 20, 2012 1:13 pm |
You checked tyre pressures?
Posted: Fri Apr 20, 2012 1:14 pm |
Yh i jus set them both to 32 just before i left
Posted: Fri Apr 20, 2012 1:15 pm |
All the correct sizes?
Posted: Fri Apr 20, 2012 1:22 pm |
Were they balanced?
Posted: Fri Apr 20, 2012 1:24 pm |
Yeah he balanced them on a machine
Posted: Fri Apr 20, 2012 1:29 pm |
Trade Rating: +16
sounds like tracking?
wheels all been torqued up? I would call the aa to check before moving the car.
Posted: Fri Apr 20, 2012 1:36 pm |
Stigter wrote: |
wheels all been torqued up? I would call the aa to check before moving the car. |
Sorry dont no what torqued is and im not a member with any company aa or rac would they come to check still if i call ?
Posted: Fri Apr 20, 2012 1:44 pm |
I think they would - but they may apply a fee.
Posted: Fri Apr 20, 2012 1:47 pm |
they will, but who knows how much are they going to charge you.
can't believe people don't even have basic cover
Thanks il try now
Posted: Fri Apr 20, 2012 1:49 pm |
gaffa786 wrote: |
I just had 3 new tired put on my car wel part worn. I just got onto the motorway and when id get of the gas ghe car turns n when i break it turns to the left bit scary with it turning it self so i had to quikly get of the motorway n park up. In manchester any ideas please i realy need to get to birmingham tonight |
Did they not teach English when you went to school?
Posted: Fri Apr 20, 2012 1:59 pm |
guessing as he is out and about - its sent from his phone.
Trade Rating: +16
Seabook wrote: |
can't believe people don't even have basic cover |
its only £5 a month if that.
but then again look how much it is to get insured these day, im getting quotes of £3000 on a 1.1!
