Latest: Stu-mill
Overall: 17131
Online Now [320]:
Visitors: 319
Today: 15687
Total: 104824551
Forums › The Car › 206 Problems › eml light
eml light
pazza
PostPosted: Wed Apr 25, 2012 4:31 pm Up
P0170 fault code fuel trim malfunction ........ could this be the front lambda sensor plese??????
paz
Deckchair5
PostPosted: Thu Apr 26, 2012 12:46 am Up
It might be lots of things, the car is warning you that it is having to trim the fuel injected to an unacceptable level so you need to find out what is causing that. I'd reset the code and see if it happens again. If you can, monitor your lambda sensor whilst engine running
A simple misfire can also cause fuel trims to want to go to max to compensate so check your plugs
