Posted: Wed May 02, 2012 2:19 pm |
get a second hand sump as stated Easy fix,
Posted: Wed May 02, 2012 2:20 pm |
i wouldn't know where to look for one
It's an alloy sump so won't be corroded. The tube is the probe from the oil level/temp sensor.
The oil pump is level with the bottom of the block not in the sump.
think if it was me i would get the pump sorted (and pick up) bolt a new sump on fill up with fresh oil and see what it sounds like when started mate you will soon know if you got a major problem
Posted: Wed May 02, 2012 2:21 pm |
well if you are really running short of cash you can always buy a welder a pint
Posted: Wed May 02, 2012 2:22 pm |
If its the speedbump at fault you could possibly claim from the council? Not 100% on that but its been done before!
Posted: Wed May 02, 2012 2:30 pm |
Dan- wrote: |
i wouldn't know where to look for one  |
Well you might be lucky and someone on here knows of one!
Otherwise I use ebay to track down people breaking Pugs and contact them, or there are specialist breakers ... try google.
You could use one the breaker-search sites like 247spares or partsgateway.
You tell them what you want and wait for the calls. There are a few sites like that.
Posted: Wed May 02, 2012 2:35 pm |
Is your car unusually low? If so I'd be looking for some compensation from the council or who ever maintains the road,
Posted: Wed May 02, 2012 2:54 pm |
i wouldn't say its that low tbh, I'm going to ring them up tomorrow and see what they say about it!
Posted: Wed May 02, 2012 3:11 pm |
How fast were you driving? It takes some force to do that...
spike_202 wrote: |
My Powerflow is quite loud but then again it's on ITBs and has a decat. |
Audi Sport  | |
Posted: Wed May 02, 2012 3:25 pm |
i hit it at about 25 like any other speed bump "/
Posted: Wed May 02, 2012 3:50 pm |
Trade Rating: +36
Ouch. I did this on my old Capri and couldn't claim as the car had been lowered. However my engine was fine and it had been running about ten seconds afterwards. I sourced a replacement sump from a knackered engine that was being scrapped and swapped them over. Did the job. Now I know that was a older engine with but theoretically because you turned it off do quick I would say the chance of major damage would be slim. Also 25mph over a speedbump, I take them nice and slow lol. Already lost a piece of exhaust a few weeks ago and after seeing that I will be going even bloody slower now.
Posted: Wed May 02, 2012 5:35 pm |
Cost me 400 inc rad an fitting of new sump
Posted: Wed May 02, 2012 5:37 pm |
Reminds me of when my mate had is unreasonably low Corsa. I towed him 3 times when he smashed his sumps.
Posted: Wed May 02, 2012 8:57 pm |
If anybody knows if the 180 sump is the same as the 138 sump then you can buy my 138 sump.
