Online Now [350]:
Visitors: 349
Today: 58634
Total: 105321907
Forums › The Car › 206 Problems › just had a bad accident
iainlovatt
PostPosted: Wed May 02, 2012 2:19 pm Up
get a second hand sump as stated Easy fix, Smile
(My Garage)
Dan-
PostPosted: Wed May 02, 2012 2:20 pm Up
i wouldn't know where to look for one Sad
It's an alloy sump so won't be corroded. The tube is the probe from the oil level/temp sensor.
The oil pump is level with the bottom of the block not in the sump.
broadblaster
think if it was me i would get the pump sorted (and pick up) bolt a new sump on fill up with fresh oil and see what it sounds like when started mate you will soon know if you got a major problem
on a back road playing
PostPosted: Wed May 02, 2012 2:21 pm Up
well if you are really running short of cash you can always buy a welder a pint
Reflekt.
PostPosted: Wed May 02, 2012 2:22 pm Up
If its the speedbump at fault you could possibly claim from the council? Not 100% on that but its been done before!
2.0 HDi Moonstone Blue Progress Thread
2.0 HDI... Carbon front badge, Black rear lights, PH2 bootstrip, Honeycombe grill
gazza82
PostPosted: Wed May 02, 2012 2:30 pm Up
Well you might be lucky and someone on here knows of one! Cool
Otherwise I use ebay to track down people breaking Pugs and contact them, or there are specialist breakers ... try google.
You could use one the breaker-search sites like 247spares or partsgateway.
You tell them what you want and wait for the calls. There are a few sites like that.
spike_202
PostPosted: Wed May 02, 2012 2:35 pm Up
Is your car unusually low? If so I'd be looking for some compensation from the council or who ever maintains the road,
**spike's project**
TEAM:+200bhp
Dan-
PostPosted: Wed May 02, 2012 2:54 pm Up
i wouldn't say its that low tbh, I'm going to ring them up tomorrow and see what they say about it!
PostPosted: Wed May 02, 2012 3:11 pm Up
How fast were you driving? It takes some force to do that...
Dan-
PostPosted: Wed May 02, 2012 3:25 pm Up
i hit it at about 25 like any other speed bump "/
-Dave-
PostPosted: Wed May 02, 2012 3:50 pm Up
Trade Rating: +36
Ouch. I did this on my old Capri and couldn't claim as the car had been lowered. However my engine was fine and it had been running about ten seconds afterwards. I sourced a replacement sump from a knackered engine that was being scrapped and swapped them over. Did the job. Now I know that was a older engine with but theoretically because you turned it off do quick I would say the chance of major damage would be slim. Also 25mph over a speedbump, I take them nice and slow lol. Already lost a piece of exhaust a few weeks ago and after seeing that I will be going even bloody slower now.
Ex 206 Owner.
00budham00
PostPosted: Wed May 02, 2012 5:35 pm Up
Cost me 400 inc rad an fitting of new sump
Rob2859
PostPosted: Wed May 02, 2012 5:37 pm Up
Reminds me of when my mate had is unreasonably low Corsa. I towed him 3 times when he smashed his sumps.
PostPosted: Wed May 02, 2012 8:57 pm Up
If anybody knows if the 180 sump is the same as the 138 sump then you can buy my 138 sump.
Page 2 of 4
