Latest: Beduff1977
Overall: 17134
Online Now [1014]:
Visitors: 1013
Today: 51523
Total: 107232371
Forums › The Car › 206 Problems › Oil Leak Help
Oil Leak Help
DiddlesDee
PostPosted: Thu May 03, 2012 11:41 am Up
Hi guys, I've recently noticed a patch of oil building up on my driveway so I had a quick look under the car today. It wasn't a pretty sight. I've posted some pics of what I saw, I was just wondering if anybody knew any obvious or could see any obvious places where it might be leaking from in the pictures?
I had the oil & filter changed about 2 weeks ago as well.. so i'm conscious, I don't know if that makes any difference.
Any help is massively appreciated.
img853.imageshack.us/i...1341tq.jpg
img265.imageshack.us/i...1342by.jpg
img689.imageshack.us/i...1343eg.jpg
img841.imageshack.us/i...g1344b.jpg
img844.imageshack.us/i...1345in.jpg
img259.imageshack.us/i...g1346w.jpg
(They're pretty large images)
DiddlesDee
PostPosted: Thu May 03, 2012 11:44 am Up
My pictures don't seem to have worked.. they appeared in the preview but aren't in my post..
*1998 Pug 206 1.1 LX old and tired but still going*
PostPosted: Thu May 03, 2012 12:07 pm Up
You missed the [img] and [/img] brackets...
simpsonrc
PostPosted: Thu May 03, 2012 1:02 pm Up
head gasket
Walton450
PostPosted: Thu May 03, 2012 1:16 pm Up
i have the same kind of leak, mine is the head but its not as bad as that. the cam shaft seal can leak down that sideof the engine. if you remove the cam belt cover and have a look if its wet around the seal.
I\'m Steve got a 2003 verve.
Tiago
PostPosted: Thu May 03, 2012 4:51 pm Up
Checked the left corner closest to you where the headgasket sits?
Mine leaks little from there, head gasket is at fault.
Deckchair5
PostPosted: Fri May 04, 2012 1:36 am Up
As it looks like there's no trace of oil above the oil filter and fluid follows gravity then it couldn't be a head gasket and as you've just had the oil filter changed and the leak was apparent immediately after then it looks simply like the oil filter has a poor seal against the engine. So either it hasn't been tightened enough or the sealing area wasn't cleaned before fitting
If a garage did that for you then that's a classic rookie mistake of not checking the oil filter is sealed after refilling with oil and running the engine. If there's no trace of oil above the oil filter then take it back and get a free engine wash as the leak is big and close to your exhaust so it's dangerous
DiddlesDee
PostPosted: Tue May 08, 2012 11:08 am Up
cheers, i'm taking it back to the same garage next week to get a cv joint replaced so i'll get him to double check the oil filter seals alright.
thanks
bezford
PostPosted: Tue May 08, 2012 12:54 pm Up
If they cant fit an oil filter properly are u sure about trusting them with your cv joint?
R.HYDE
DiddlesDee
PostPosted: Wed May 09, 2012 10:44 am Up
He's done other stuff for me before and been great, he also charges half the going rate for labour around here.. I have my doubts that it's just the oil filter seal to be honest as I know there was a bit of oil before it was changed.. I'm thinking it's probably the seal as well as something else.. I'll ask him to have a look while it's up on the ramp to see if he can see where the leak's coming from
LeeUK
PostPosted: Sun Jun 17, 2012 3:05 pm Up
Did you find out the reason behind the leak? I have the same leak.
2001 206 1.4i GLX
2001 Megane 1.6i Dynamique 16V
2008 207 1.4 HDI
2014 Focus 1.6 TDCI Titanium Nav
2020 Jaguar E-PACE Chequered Flag D150 AWD + 2002 Ford Focus 1.6 Ghia run-a-bout
