Online Now [49]:
Visitors: 48
Today: 11474
Total: 106141199
Forums › The Car › 206 Problems › 206 AirBag Light - How to Switch off?
mcburney777
PostPosted: Sat May 19, 2012 5:54 am Up
Hello,
My 2001 1.9d 206 failed the mot this morning on the airbag light being continusly on on the dash board.
Does anyone know how to turn this off?
It does not have side bags so therefore there are no plugs underneath the seats.
Many Thanks
chris
PostPosted: Sat May 19, 2012 6:02 am Up
when did you buy your car?
think solid light means deployed airbag
www.206info.co.uk/Foru...25165.html
20619d
PostPosted: Sat May 19, 2012 6:37 am Up
yep sounds like need new airbag dude. mine did this so just changed the airbag and is fine
mcburney777
PostPosted: Sat May 19, 2012 7:08 am Up
hi, i bought i bought 2 years ago just. is there any other way round this as i just want to get it thru the mot, i.e. remove fuse or anything like that?
chris
mcburney777
PostPosted: Sat May 19, 2012 7:12 am Up
would disconnecting the airbag control unit work?
chris
PostPosted: Sat May 19, 2012 7:17 am Up
is the light always on when you bought the car?
removing fuse, disconnecting airbag will make the light on
HDI90
PostPosted: Sat May 19, 2012 7:31 am Up
Im sure you can put some kind of resister in the loom somewhere to trick it , some one did it once with a after market steering wheel
GTI 180
mcburney777
PostPosted: Sat May 19, 2012 7:34 am Up
yeah its always been on, im not sure what to do. its beating me here atm
chris
PostPosted: Sat May 19, 2012 7:40 am Up
won't work if the airbag has been deployed.
PostPosted: Sat May 19, 2012 8:15 am Up
Remove the bulb / tape over the airbag warning light & its pass & advise.
f*****g VOSA w**kers have stuffed up the new mot test rules Rolling Eyes
Uz
PostPosted: Sat May 19, 2012 9:06 am Up
Take the clocks apart and tape over both of the airbag lights from the inside and also disconnect your mfd if it's one of the one where airbag fault come up before you go back in, always reconnect mfd afterwards.
PostPosted: Sat May 19, 2012 9:40 am Up
If yours is pre plex ive got the airbags and ecu from my GTi im breaking availible for sale.
Also to make sure we havent missed the idiot bit, is the passenger airbag switched off on the switch next to the headlight adjusters?
mcburney777
PostPosted: Sat May 19, 2012 10:13 am Up
lol yes its switched of. tried plenty of things, still no joy, is it hard to take the clocks apart?
chris
PostPosted: Sat May 19, 2012 10:16 am Up
Switch it back on....?
PostPosted: Sat May 19, 2012 1:32 pm Up
Well you all giving a solution for something wrong,it must be fixed,not for the MOT sake,but for the driver and passenger sake,beacuase airbag is very important and can save your life,so get it scanned,and see what is wrong,fix it,and it will PASS.
