Latest: airmastertapes
Overall: 17133
Online Now [305]:
Visitors: 304
Today: 144355
Total: 106856153
Forums › The Car › 206 Problems › Changing gear cables
canonfire
PostPosted: Mon May 28, 2012 6:11 am Up
After what I thought was a broken selector turns out to be one of the gear cables had popped off the ball on top of the gearbox. I've pushed it back on and its fine now but it's only a matter of time before it happens again as it looks like the insert on the cable end is quite worn......
Are these fairly straightforward to replace?
thanks Smile
2004 Peugeot 206 GTi 180
PostPosted: Mon May 28, 2012 6:53 am Up
Well youve seen how easy it is to put back on its just the same taking them off.
imjeeves
PostPosted: Mon May 28, 2012 1:58 pm Up
Not a nice job at all to replace. You have to remove two very awkward bolts on the top and back of the gearbox to pull the whole unit out
canonfire
PostPosted: Mon May 28, 2012 2:38 pm Up
Thanks for the replies, i'll give it a go, otherwise Peugeot will have to do it........
