Latest: ArtistKS
Overall: 17145
Online Now [51]:
Visitors: 50
Today: 2791
Total: 116096011
Forums › The Car › 206 Problems › 1.1 tickover problem
elland_canary
PostPosted: Sat Jun 09, 2012 7:37 am Up
Have a w reg 1.1, won't idle. As soon as you lift off it stalls, runs fine if revved, will rev smoothly right through the range until you lift off then stalls. Starts first time as long as have foot lightly on accelerator. Was told probably MAP sensor, have changed that but made no difference, any ideas?
206 owner
-Dave-
PostPosted: Sat Jun 09, 2012 7:41 am Up
Trade Rating: +36
Give the ICV a clean, That may help.
Ex 206 Owner.
Davies
PostPosted: Sat Jun 09, 2012 8:05 am Up
As Dave said, sounds like a ICV Issue, there is a how to on the forum on how to give it a clean, its literally a 5 minute job and can work wonders!
Poppy, My 2.0 HDI Dream Wink
elland_canary
PostPosted: Sat Jun 09, 2012 9:47 am Up
have tried cleaning out ICV, not made a blind bit of difference Sad
stumped again, thanks for suggestions though, any further suggestions appreciated
206 owner
Deckchair5
PostPosted: Sat Jun 09, 2012 12:00 pm Up
Still sounds like the ICV / idle stepper motor. Perhaps it's simply died. It would be nice to check it out first though.
Try a wiggle test of the ICV connector whilst it's trying to idle. See if it makes a difference
Remove the ICV, connect its connector and see if the valve moves when you turn ign on/off
Check if power/ signal is arriving at the ICV
Check the resistances through the ICV terminals
They are only around £15 new if it is dead
elland_canary
PostPosted: Sat Jun 09, 2012 12:23 pm Up
will try that tomorrow, thanks for tip, modern (!) cars got too many gadgets on them, did all my tinkering on 70's fords and vauxhalls, much simpler to diagnose.
206 owner
Davies
PostPosted: Sun Jun 10, 2012 12:55 am Up
Failing that, I had a issue slightly similar, but the car was revving up even whilst driving it, thus pulling me down the road.
It came out to be the MAP sensor.
Jack
