Online Now [549]:
Visitors: 548
Today: 73425
Total: 105650375
Forums › The Car › 206 Problems › 206 GTi jumps out of 5th gear
Nathan107
PostPosted: Wed Jun 13, 2012 2:52 pm Up
Can anyone point me in the right direction?
For the first time ever I was driving at 50mph and come of the throttle and it came out of 5th gear. I dipped the clutch and re-engaged it for it to come out again a few hundred yards down the road (motorway sliproad).
Is this the start of a faulty gearbox or selector rods (I have noticed that the gearstick has been sloppy fo a while)?
Thanks.
The car has done 87k if it is relevant?
follow me on twitter: nathanreardon1
PostPosted: Wed Jun 13, 2012 3:07 pm Up
could be engine mount as well.
Nathan107
PostPosted: Wed Jun 13, 2012 3:08 pm Up
If the engine mount was faulty wouldnt this affect all gears?
PostPosted: Thu Jun 14, 2012 5:12 am Up
it depend on how worn is the gear and the amount of vibration
Nathan107
PostPosted: Thu Jun 14, 2012 5:48 am Up
Okay.
The strange thing is I did the same journey but on the way home and it didnt fall out of gear?
Very confused now. I only have movement in the gearstick when it is in 5th gear and it feels tight in the other 4.
PostPosted: Thu Jun 14, 2012 9:50 am Up
I had my 2nd gear synchro changed under warranty...after that 5th gear would jump out when lifting off the throttle, so they changed that gear too. Fixed now.
Nathan107
PostPosted: Thu Jun 21, 2012 2:18 am Up
Thanks Edward.
Funny thing is it hasnt done it since..Is it time to sell the beast?
