Online Now [574]:
Visitors: 574
Today: 54742
Total: 105193914
Forums › The Car › 206 Problems › Starting issues with my car :(
jstone
PostPosted: Thu Jun 14, 2012 11:39 am Up
Hi everyone, i really need some help the car has been to 3 garages and they have looked over and have found no problems except flat battery which has been replaced.
The car has starting issues where one day i can go out and crank her and she will start after 3 ish seconds then i could go out and have to crank her 3 times plus and even then she really struggles to fire. as she is cranking she seems to completly die then crank and fire. As i say this does not seem to happen all the time and the garages are not finding any faults. there really is no rhyme nor reason for this i can try when i first turn on ignition lights or waiting for the airbag light to go out.
I am seriously running out of funds with garage after garage coming up with nothing. Any help would be gratefully recieved
Thank you everyone for help
PostPosted: Thu Jun 14, 2012 12:45 pm Up
what car do you have?
NICKST
PostPosted: Thu Jun 14, 2012 2:46 pm Up
I have just had a customers vauxhall corsa in all week with same issue turned out to be a faulty crank sensor was giveing off no fault codes either.
Deckchair5
PostPosted: Thu Jun 14, 2012 3:29 pm Up
What He Said
Sounds very much like a crank sensor type fault. No fault codes are logged because the ECU is waiting for the engine to start turning, it's not going to allow fuel/sparks until the engine is doing a minimum rpm, so it waits and waits, not realising the engine is already turning and doesn't think there's anything wrong
On a good day it senses the rpm straightaway and off you go
PostPosted: Thu Jun 14, 2012 3:40 pm Up
Yep, id put my money on crank shaft position sensor as well.
jstone
PostPosted: Fri Jun 15, 2012 11:03 am Up
206 1.4glx is the car that i have, I will talk to my bro and see if he has dont the crank shaft sensor and let you know Thanks for comments so far.
