Latest: tbafonso
Overall: 17130
Online Now [190]:
Visitors: 189
Today: 67968
Total: 103734768
Forums › The Car › 206 Problems › Got Air conditioning Re-gassed but still no cold air?
very_452001
PostPosted: Sat Jun 23, 2012 5:43 pm Up
I got my air conditioning regassed a couple of days ago by a oft approved bosch service garage and so far notice there's no ice cold air coming from the vents.
there's no difference between A/C off or on infact.
Please advise
very_452001
PostPosted: Sat Jun 23, 2012 5:50 pm Up
Did you get them to actually check the pump? Or just regas the system?
purrjoe
PostPosted: Sat Jun 23, 2012 11:30 pm Up
Also, is the radiator fan working when you switch the aircon on ? Confused
PostPosted: Sun Jun 24, 2012 12:47 am Up
that can be caused with many things,maybe the pump is not working well,or the filter ( Dryer) that is located in the front area next to the radiators is full of moisutre and need to be replaced,and make sure that the fan kicks in when the A/C on,and you hear a click sound.
brad-morris
PostPosted: Sun Jun 24, 2012 12:57 am Up
This comes up so often, as you haven't stated if you have got the leak fixed not "re-gassed" if you've lost refrigerant you have a leak end of.
PostPosted: Sun Jun 24, 2012 2:00 am Up
Please advise
Take it to a aircon specialist that actually knows what there doing.
Deckchair5
PostPosted: Sun Jun 24, 2012 2:25 am Up
What He Said
Without the system actually running and working then it's impossible to be sure it has been refilled properly. Just pumping some gas in doesn't do the job
very_452001
PostPosted: Sun Jun 24, 2012 3:09 am Up
I told them to regass the air con cause that's what I thought it needed. I didn't know about filters, pumps, fans, radiators, leaks at the time. They are suppose 2 check that before regassing right?
very_452001
andyleep
PostPosted: Sun Jun 24, 2012 3:16 am Up
A leak somewhere
You asked them to regass it so thats whay they did.
A proper aircon service on a working system should take around an hour.
Thats for a vac out including system pressure check, re gas & re oil including UV dye then run up to check the system is working correctly & is still gas tight.
The vac out & pressure check alone should be at least 30 mins.
DeadEyePaul
PostPosted: Sun Jun 24, 2012 3:21 am Up
Many garages can add a UV dye into the gas and allow it to leak then use a UV lamp to detect where your
Leak is
very_452001
PostPosted: Sun Jun 24, 2012 6:14 am Up
Leak is
if there's a leak then what does the garage has to do?
very_452001
PostPosted: Sun Jun 24, 2012 8:29 am Up
very_452001 wrote:
Leak is
fix the leak? Confused
very_452001
PostPosted: Sun Jun 24, 2012 4:54 pm Up
Seabook wrote:
very_452001 wrote:
Leak is
do they fix the part or replace it?
very_452001
spike_202
PostPosted: Mon Jun 25, 2012 12:24 am Up
Leak is
This is very clever, didn't know they did such a thing.
I would asume they would just fit some new pipe or alloy wield the hole or could be a joint that's leaking in that case they'll replace the fixing.
**spike's project**
TEAM:+200bhp
Page 1 of 5
