Latest: Puggingalong
Overall: 17129
Online Now [267]:
Visitors: 266
Today: 15256
Total: 100936895
Forums › The Car › 206 Problems › which coolant
which coolant
jmcdyre
PostPosted: Mon Jul 09, 2012 5:35 am Up
Hi all,
apologies if this is a ridiculously simple question but I can't find my handbook. Does anyone know what coolant I should buy for a 2001 Y reg 206 GLX 1.6
J
JM
PostPosted: Mon Jul 09, 2012 5:54 am Up
BASF Glysantin® G33
PostPosted: Mon Jul 09, 2012 8:05 am Up
Is it just for topping up OR are you flushing the system out & replacing all the coolant?
If its a full flush out then go for a long life / 5 year coolant.
PostPosted: Mon Jul 09, 2012 1:30 pm Up
Get Pug coolant only.
I hear some long-life stuff (RED) wrecks the vains of the engine and can spoil seals/gasket.
Pug is long-life 5 year but is light-green/blue.
It goes to show that colour does not determine 2 or 5 year service cycle.
PostPosted: Mon Jul 09, 2012 1:33 pm Up
Antifreeze needs to be OAT type for the 206.
PostPosted: Mon Jul 09, 2012 1:39 pm Up
Correct.
This is what causes confusion because people always think of OAT as red colour,
whereas pug OEM is OAT and is bluish green.
PostPosted: Mon Jul 09, 2012 1:42 pm Up
People shouldnt go by the colour, they should read the bottle for the spec Whistle...
Mines got long life orange OAT stuff in as I changed it the other week when I did the water pump.
PostPosted: Mon Jul 09, 2012 2:08 pm Up
i think i have said that before.
all those fancy color are all artificially added. All engine coolant (whether is OAT or silicate/phosphate) are colorless by nature.
206boyracer
PostPosted: Mon Jul 09, 2012 2:13 pm Up
What is OAT then what makes it different?
206 GTI 138.
PostPosted: Mon Jul 09, 2012 2:14 pm Up
It basically protects the aluminium used in the engine.
Stick a non OAT coolant in & after a while it will damage the engine internals & then spring a leak from one of the seals.
OAT = Organic Acid Technology
206boyracer
PostPosted: Mon Jul 09, 2012 2:17 pm Up
Ah. Ok. I just bought some at the weekend. Off to check Its the right stuff now. Thanks.
206 GTI 138.
206boyracer
PostPosted: Mon Jul 09, 2012 2:23 pm Up
Phew. Thank god for that. Nearly had a cold sweat tho. Didn't see it on the label until I peeled it open and read inside.
206 GTI 138.
PostPosted: Mon Jul 09, 2012 2:25 pm Up
right, basically most engine coolant nowadays are all glycol (propylene or ethylene, some even use glycerol) and water.
In order to prevent corrosive, rust inhibitor must be added.
traditional phosphate or silicate (inorganic inhibitor) are good for cast iron engine but not so good for aluminum due to their slightly alkaline nature.
OAT stands for organic "organic acid technology"; normally they use triazine analogue as the rust inhibitor, due to the acidic nature they are fine to use with aluminum and ferrous metal but not so good with copper or lead.
depends on the exact formula of the rust inhibitor they will have different tolerances to rubber seal.
anton1989
PostPosted: Mon Jul 09, 2012 2:31 pm Up
Trade Rating: +16
any engine 206? never knew this will be doing a flush at the weekend i think Shocked
PostPosted: Mon Jul 09, 2012 2:33 pm Up
all 206 used OAT stuff.
