Latest: sparrowdclxvi
Overall: 17139
Online Now [140]:
Visitors: 139
Today: 1528
Total: 113333775
Forums › The Car › 206 Problems › Rattling heat shield.
Sprotty
PostPosted: Thu Jul 12, 2012 1:43 am Up
Got a rattling heat shield on the manifold of my gti 180. Bolts are too corroded to tighten. Has anyone just removed the heat shield without any issues?
Life at full throttle...
Razor34
PostPosted: Thu Jul 12, 2012 2:04 am Up
I am pretty sure from what I have read on here before that you can just take these off no problems
Ray
Jack123
PostPosted: Thu Jul 12, 2012 2:08 am Up
www.ebay.co.uk/itm/Peu...500wt_1361
Cherry Red 206 1.1 99'
Wanted List;
Crystal Headlights.
PM Me if you are selling!
Sprotty
PostPosted: Thu Jul 12, 2012 2:13 am Up
The heat shield is fine, just the bolts are knackered and worn.
Jack123
PostPosted: Thu Jul 12, 2012 2:16 am Up
Ah, just figured you might end up butchering it getting it off.
But yeah, if you can remove it, you can remove it, it should be fine to remove.
Wanted List;
Crystal Headlights.
Sprotty
PostPosted: Thu Jul 12, 2012 2:21 am Up
Heat shield is different anyways!
PostPosted: Thu Jul 12, 2012 2:57 am Up
It's been designed to protect something from the heat coming from the manifold. Car companies don't spend time and money doing research, design and manufacturing on something that isn't needed.
Clean up the threads and buy a new nut and bolt. Probably cost less than £1 to sort it out.
Big_Rich180
PostPosted: Thu Jul 12, 2012 4:51 am Up
Jack123 wrote:
http://www.ebay.co.uk/itm/Peugeot-206-Saxo-Exhaust-heat-shield-/251102405466?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3APeugeot%7CModel%3A206&hash=item3a76dea35a#ht_500wt_1361
Lol, I cant imagine this fitting very well.
Sprotty
PostPosted: Thu Jul 12, 2012 5:45 am Up
Got it sorted, managed to get the offending bolt out and replace it with a washer fitted aswell and all is good now!
