Latest: tbafonso
Overall: 17130
Online Now [364]:
Visitors: 363
Today: 37039
Total: 103546272
Forums › The Car › 206 Talk › UPDATE -- Changing the ECU (Can it be done?)
southwestchap
PostPosted: Thu Jul 19, 2012 3:05 am Up
Having a few probs with a 2002 D-Turbo 206, still working on it though only got the evenings with it so try and work out things to try during the day.
Other Thread
Just want to throw question(s) out there for some clarification.
I have no communication to the Engine ECU through PP, this could be the loom possibly. would there be a possibilty that if I had a known working ECU that I could plug it into the car and get a reply...to test the loom basically. I know that it wouldnt run but even if i got a ECU mismatch message that would be something.
This sort of leads me on to the next question.
If im unable to get anywhere, its going to be a case of replacing the ECU, am i correct in saying that I can't just get another engine ECU off a 2.0hdi 206 and put it on...even though i have access to PP could i not just recode (or whatever) the ECU to the car?
If not, what are the main componants that have to be changed together? ECU, BSI and ...? Could this come from a standard 2.0HDI Mux? or ideally from the D-Turbo Model?
Cheers All
PostPosted: Thu Jul 19, 2012 4:41 am Up
You can change the ecu's over providing the numbers on the underside match to the new ecu but ensure its un-coded
PostPosted: Thu Jul 19, 2012 5:29 am Up
You need one that matches your electrical system, pre plex or multiplex. The cheapest and easiest way is to buy a complete set from the same car including ecu, bsi, transponder Ariel and the transponder chip for the key. This way you dont need to spend money on getting them re-coded.
southwestchap
PostPosted: Thu Jul 19, 2012 5:52 am Up
by uncoded do you mean unlocked?
PostPosted: Thu Jul 19, 2012 6:54 am Up
This, replace all four things from another car and it will work fine don't need to p**s around trying to unlock stuff and it will be the cheapest option, takes 20 minutes max to fit
southwestchap
PostPosted: Thu Jul 19, 2012 6:59 am Up
spied on ebay a ecu (same numbers as the one on the car), key and transponder unit...but no BSI. guessing that would be a fail still Sad will message matey and see if he has the BSI..
PostPosted: Thu Jul 19, 2012 7:40 am Up
You also need the transponder ring and chip out of the key if you want it to be a straight swap
PostPosted: Thu Jul 19, 2012 7:44 am Up
Yeah i do mate
PostPosted: Thu Jul 19, 2012 11:02 am Up
You DON'T need the transponder ring, they are not coded or locked to the car, its only an aerial to read the chip inside the key.
PostPosted: Thu Jul 19, 2012 11:29 am Up
If you need a plug and plug ECU, give me a shout.
PostPosted: Thu Jul 19, 2012 2:58 pm Up
Which is in the transponder ring..?
PostPosted: Thu Jul 19, 2012 3:02 pm Up
Round the ignition barrel.
It's only a aerial
PostPosted: Fri Jul 20, 2012 6:18 am Up
That's what I was referring to, must be getting names confused that's what I've always called it
southwestchap
PostPosted: Wed Jul 25, 2012 5:08 am Up
What are these "plug and play" ecu's?
I have spied a whole electronic set i.e. ECU, BSI, Key fob, Ignition ariel and BSM fuse box and all the numbers match on each part...
Though its from a 2003 SW HDi. whereas I have a 2002 D Turbo HDi...should this matter...even if all the codes match exactly?
Just waiting on a price at the moment.
PostPosted: Wed Jul 25, 2012 8:35 am Up
Ones that have had the immobiliser function removed so you plug it in & the car will start without any coding needed.
NOTE: Your car if you fit one will no longer have an immobiliser & your insurance company can invalidate your theft cover!
