Latest: Beduff1977
Overall: 17134
Online Now [1500]:
Visitors: 1499
Today: 83842
Total: 109938609
Forums › The Car › 206 Problems › Intermittent prob Car cuts off straight away after starting?
very_452001
PostPosted: Thu Jul 19, 2012 9:03 am Up
Hi,
I have a 2006 Peugeot 206 1.4
What Im describing is a Intermittent fault that happens at random times whether the engine is hot or cold but more likely hot i noticed. When I notice the problem first starts then the problem repeats itself until I have to manually put my foot on the gas pedal to bring the rpm over 1000 or hold key in the igniting position for a few secs to stop the engine from cutting off.
I did diagnostics on it and there's no trouble codes.
I know there could be several causes that cause this problem but what are the most popular causes for this?
thanks,
very_452001
PostPosted: Sat Jul 21, 2012 12:58 am Up
Idle control valve possibly.
very_452001
PostPosted: Sat Jul 21, 2012 6:20 am Up
cheers,
The stepper motor, Idle control valve is in the throttle body right?
very_452001
DeadEyePaul
PostPosted: Sat Jul 21, 2012 6:23 am Up
There is a nice guide on here on how to clean it! Use the search bar
very_452001
PostPosted: Sat Jul 21, 2012 6:32 am Up
ok now i know what to search for Smile
very_452001
very_452001
PostPosted: Sat Jul 21, 2012 8:50 am Up
Ok i found 2 guides:
How to clean throttle body and...
How to clean stepper motor.
Which one is reccommended?
Any of these contain Idle control valve?
very_452001
PostPosted: Sat Jul 21, 2012 9:31 am Up
If the car will still run on the throttle that would suggest the above ideas are correct. Stepper motor is same as idle control valve.
very_452001
PostPosted: Sat Jul 21, 2012 9:55 am Up
Its just that I'm a noob when it comes to mechanics and a part to have two different names to it makes it confusing lol.
So is the stepper motor inside the throttle body which means if I clean the throttle body the stepper motor gets cleaned as well right?
Otherwise why would there be 2 different guides?
very_452001
paul_c
PostPosted: Sat Jul 21, 2012 10:23 am Up
Its not 2 different names though. A stepper motor is a style of motor. An valve is a device which controls the flow of a fluid. There are lots of different kinds of valves. An idle control valve is a valve which does a particular job, and it does this by using a stepper motor to control whether its open, closed or somewhere in between.
very_452001
PostPosted: Tue Jul 24, 2012 7:07 am Up
can i use wd40 to clean it or it has to be a carb cleaner?
very_452001
PostPosted: Tue Jul 24, 2012 7:22 am Up
WD-40 will clog up most sensor.....
carb cleaner only!
very_452001
PostPosted: Tue Jul 24, 2012 8:12 am Up
carb cleaner only!
any best alternative to carb cleaner Smile
or what about putting some additives like redex in the tank. Will that clean the throttle body?
very_452001
very_452001
PostPosted: Mon Jul 30, 2012 8:17 am Up
ok i got the carb cleaner. Im following the throttle body cleaning guide and in the guide it says the MAF/MAP sensor needs cleaning so is there just one sensor thats needs cleaning and does it mean the map/maf are the same?
very_452001
