Posted: Wed Jul 25, 2012 5:31 pm |
my aerial on my 206 is in working order, its on the front on the roof (the longer aerial) i was wondering if this can be unscrewed out like the aerial that some 206's have on the rear of their roof, as i think the length of it is far to long. Also i have a leak coming in from it, does this suggest the rubber seal has gone or is this something im not aware of im not that clued up with this sort of things.
| I\'m new here, thought i\'d join as i\'ve just bought my first car, 206 1.1 zest 3 black (55) | |
Posted: Wed Jul 25, 2012 5:43 pm |
yes it unscrews out mate im guessing you will need a new seal too by the sounds of things im sure it would be pennies from ebay or your local pug dealership etc
Posted: Wed Jul 25, 2012 6:03 pm |
cheers do you know if the aeriel is a male or female connection as my cars not with me so i can scout ebay
Posted: Thu Jul 26, 2012 9:17 am |
gloves93 wrote: |
Also i have a leak coming in from it, does this suggest the rubber seal has gone or is this something im not aware of im not that clued up with this sort of things. |
Easiest fix is remove the aerial base & some clear silicone sealent before putting it back together.
This issue of the aerial leaking after a few years is a PSA design feature for at least the last 15 / 20 years
Posted: Sat Jul 28, 2012 12:26 pm |
MrBSI wrote: |
gloves93 wrote: |
This issue of the aerial leaking after a few years is a PSA design feature for at least the last 15 / 20 years  |
how does the base come off, may seem a very silly question but i dont want to break it.
Posted: Sun Jul 29, 2012 1:47 am |
gloves93 wrote: |
how does the base come off, may seem a very silly question but i dont want to break it. |
Bolt/nut on the inside of the roof. For a front mounted aerial I believe it's accessible once you remove the interior light assembly. Quick google search found a pretty clear description: clicky
| Silvermetallic 2004 206 RC | |
Posted: Sun Jul 29, 2012 5:16 am |
thanks mate!
