Latest: Worthy967
Overall: 17143
Online Now [539]:
Visitors: 538
Today: 147540
Total: 114723633
Forums › The Car › 206 Problems › had my codes read
had my codes read
anton1989
PostPosted: Wed Jul 25, 2012 12:50 pm Up
Trade Rating: +16
so i have have anti pollution fault up for a while so while at the garage having my cv boot done i had my codes read
before i start i also had an airbag fault a few days ago but this went away after i fitted my 180 seats and left the battery disconneted for over half an hour?
so this is what came up
p0100-mass or volume air flow circuit malfunction
p0571-cruise control/brake switch A circuit malfunction
p1112-rail pressure signal over the upper threshold
p1519-cooling fan
p0221-throttle/pedal position sensor/switch B circuit
p0230-fuel pump primary circuit malfunction
p0110-intake air temp circuit malfunction
faults where cleared, the car had the gear oil out so could not not start the car, i turned the ignition off, left it the done same again and the only code that came back was p0110 BUT the car hadnt been started so more may come back after it is.
it was after closing time so after my cv boot was done thy had no time to start the car and see what else came back, i will be going back tomorrow to what comes up
anyway on the drive bag my airbagfault came back! this had been gone for a few days. the anti pollution fault seems to have gone though?
so if these faults have come back when i check tommorow what needs doing? i take it p1519 means i have no cooling fan Shocked how do i know whats wrong with it
why did my airbag fault go then come back after i had the codes read?
any help much appriciated
by the way the guy never knew much about the codes he left me to check it myself as he did my cv boot
PostPosted: Wed Jul 25, 2012 1:39 pm Up
i got P0110 as well, it turns out is one of the wire on the plug (on the MAF) was snapped.
just work it through step by step, those code aren't complicated,
anton1989
PostPosted: Wed Jul 25, 2012 2:30 pm Up
Trade Rating: +16
cheers seabook
did this bring up your anti polution fault?
i have no idea where to start or what im looking for to fix Confused
PostPosted: Wed Jul 25, 2012 2:32 pm Up
anton1989 wrote:
cheers seabook
nope. if the circuit was open, the default air intake temperature will be set at 50 (maybe 60) by ECU;
start from the sensor and work from there, most likely will be bad connection/ broken plug/ broken earth.
anton1989
PostPosted: Wed Jul 25, 2012 2:45 pm Up
Trade Rating: +16
Seabook wrote:
anton1989 wrote:
cheers seabook
ok will have a look over the weeknd.
what about the other codes if they have come back? where do i start on them?
PostPosted: Wed Jul 25, 2012 7:44 pm Up
if you scan it with pp2000 it will have the step by step diagnostics guide
anton1989
PostPosted: Thu Jul 26, 2012 5:52 am Up
Trade Rating: +16
Not sure what the scanner is, will find out later
it had to parts, the bit that went into the part near fuse box, this had lead that went to a box, then a hand held pc type thing th where the codes come up on
anton1989
PostPosted: Thu Jul 26, 2012 10:26 am Up
Trade Rating: +16
ok so been and had the codes read again
the airbag fault is;
3 passenger squib 1st circuit, open circuit
what could this be? whats squib?
also these are the codes that have come back from the seven i had yesturday;
p0110
p1108 - this is a new one? and is also the cooling fan, i have two fault codes for cooling fan?
p0100
p0571
p1519
see 1st post for what the codes are
any help much appreciated
anton1989
PostPosted: Thu Jul 26, 2012 11:00 am Up
Trade Rating: +16
anyone?
worried about my airbags not working
mtempsch
PostPosted: Thu Jul 26, 2012 11:01 am Up
A squib is a small electrically initiated explosive device (for instance also used to set of dye packs in movies simulating gunshot wounds).
In this case it's the initiator for the main gas generating charge; if if enough current runs through it, it heats up, sets of the small sensitive initiator charge which in turn sets off the main charge.
Since it says open circuit it means there's no current at all being passed through - ie probably a wiring issue to the airbag.
Silvermetallic 2004 206 RC
anton1989
PostPosted: Thu Jul 26, 2012 11:12 am Up
Trade Rating: +16
thanks mtempsch
it says says passenger side, how will i know if its the seat or airbag in the dash?
where mr-bsi and lee!!!
no offence mtempsch
PostPosted: Thu Jul 26, 2012 11:14 am Up
anton1989 wrote:
where mr-bsi
Im right here Razz
anton1989
PostPosted: Thu Jul 26, 2012 11:19 am Up
Trade Rating: +16
MrBSI wrote:
anton1989 wrote:
where mr-bsi
Im right here Razz
where you been!!!!!!
can you help please? had the codes read like you said to
PostPosted: Thu Jul 26, 2012 11:21 am Up
anton1989 wrote:
MrBSI wrote:
anton1989 wrote:
where mr-bsi
Im right here Razz
Confused
I've been on here for a bit everyday answering threads.
anton1989
PostPosted: Thu Jul 26, 2012 11:25 am Up
Trade Rating: +16
not mine.
