Latest: Beduff1977
Overall: 17134
Online Now [1407]:
Visitors: 1406
Today: 92482
Total: 107494153
Forums › The Car › 206 Problems › Lot of road noise?
Lot of road noise?
A10PSW
PostPosted: Thu Aug 09, 2012 12:46 am Up
Hi
I have recently purchased a 2005 Peugeot 206 1.4 HDI so I am unfamilier with how it should sound!
There seems to be a lot of road noise when driving along and gets louder the faster I go, is this normal for the 206?
Its still there when I take it out of gear.
I have just had a Full service and MOT and the mechanic said the bearings are fine when he listen to them with a Tethascope.
Apart from the noise its a great little car.
Any advise please?
Rob2859
PostPosted: Thu Aug 09, 2012 1:14 am Up
Could be crap tyres or you are used to something with better quality.
DanT
PostPosted: Thu Aug 09, 2012 1:45 am Up
As said tyres make a big difference. They're not the quietest cars to be in anyway though. I would have thought the tyres are the main factor to be honest if everything's mechanically sound.
PostPosted: Thu Aug 09, 2012 10:34 am Up
What He Said
As I get older the road noise of my 206 starts to annoy me more, just reminds me next time to get something better built with more sound proofing.
devildriverxii
PostPosted: Fri Aug 10, 2012 2:15 pm Up
Get a decent/loud audio set-up.
Problem solved.
2002 1.6 5dr Black Edition.
PostPosted: Fri Aug 10, 2012 2:22 pm Up
Problem solved.
still the same. too noisy in the cockpit Confused
Rob2859
PostPosted: Fri Aug 10, 2012 6:17 pm Up
Problem solved.
Plus a big sub will just cause more rattles...
PostPosted: Sat Aug 11, 2012 1:53 am Up
Dont notice any road noise at all in mu 206....
A10PSW
PostPosted: Mon Oct 29, 2012 4:46 am Up
I have now fitted Alloys and the road noise has been greatly reduced.
Thank god for that as I thought maybe the rear axle bearings were on there way out! Smile
PostPosted: Mon Oct 29, 2012 10:42 am Up
With the WRONG wheel bolts Wink
A10PSW
PostPosted: Mon Oct 29, 2012 10:50 am Up
They hold the wheels on!! Laughing
Just ordered some longer ones!
Big_Rich180
PostPosted: Mon Oct 29, 2012 10:52 am Up
They wont for long Laughing
