Latest: S2cgm
Overall: 17178
Online Now [56]:
Visitors: 55
Today: 54054
Total: 136525546
Forums › The Car › 206 Problems › 1.4 LX Power Steering Hose Removal
deadwabbit
PostPosted: Fri Aug 10, 2012 4:20 pm Up
Hi Guys,
i'm hoping for a little advice about the best way of removing the high and low pressure power steering hoses, where they enter the steering rack.
there is a bolt between the two hoses, which needs removing in order to pop the hoses out the rack and replace them with new ones, but i can not see it directly.
my question is....what size and shape is that bolt head??, i dont seem to be able to get any of my allen keys in it and i was wondering if it might be a TORX head instead? Its a little Bu**er to get to also so if anyone has any tips or hints i would really apreciate knowing them? (i.e is it best ot do it on a ramp, or use a jack and remove the driver side wheel for better access)
thanks all!!
GRR
PostPosted: Fri Aug 10, 2012 10:23 pm Up
the best way to take it off is to take the power steering pump out,and this way you will have easy access to what you need.
PostPosted: Sat Aug 11, 2012 12:17 am Up
Not to get to the section he is on about. Wink
tamz
PostPosted: Mon Jul 15, 2013 12:17 pm Up
does anyone know the answer of how to get the pipes off from the steering rack end
