Latest: tebas93089
Overall: 17179
Online Now [165]:
Visitors: 164
Today: 65387
Total: 137735896
Forums › The Car › 206 Problems › 206 gti 138 temp 98-100 when standing still, 80-90 when run
scoop
PostPosted: Mon Nov 28, 2011 4:08 am Up
i have been living with this for a year, any clue why does the temp rise to 100 when standing still?? does it concern resistor that is mounted right next to the fan?? and could there be any damage that happened to the engine after all this time??
ahmed
colganraz
PostPosted: Mon Nov 28, 2011 4:16 am Up
have you checked the fan is working ?
Former 206 XSi owner - Now 207 GT
www.206info.co.uk/Foru...56475.html
scoop
PostPosted: Mon Nov 28, 2011 4:19 am Up
yes it works,but i am not sure if it is working as powerful as it is supposed to, and radiator water level is full.
ahmed
PostPosted: Mon Nov 28, 2011 7:34 am Up
Its normal, as long as the fan kicks in to bring the temp back down. Mine kicks in at just over 90. The temp normally sits around 85 to 90 though. If your sat still youve got no airflow over your radiator, so there temp will go up.
LeeMaddern
PostPosted: Mon Nov 28, 2011 8:07 am Up
Petrols get hot when stood still, diesels cool down. Its just how it is Smile
More photos on FaceBook - www.facebook.com/lmaddern1
panzer360gti
PostPosted: Mon Nov 28, 2011 10:20 am Up
Try a radiator flush to clean the system out make it a bit more efficient? I did this and fitted a new thermostat, cleaned the coolant temp sensor, never gets above 90, even stood still.
Peugeot 206 GTI 137 2.0
PostPosted: Mon Nov 28, 2011 11:02 am Up
I guess the weather is just hotter in your part of the world then over here in the UK Wink
Reason temp will rise when standing still is the lack of forward airflow through the radiator.
Are both fan speeds working correctly?
Maybe a better radiator will help with cooling, no idea if Peugeot fit a normal / Europe spec radiator on hot climate cars Confused
Linkpad
PostPosted: Wed Nov 30, 2011 7:58 am Up
Mine does this so i turn the Aircon on and the temp goes down 10 degrees as the fan cools the radiater.
Boo
PostPosted: Wed Nov 30, 2011 12:28 pm Up
The low speed fan isn't audible over the sound of the engine. The high speed fan is loud so you'll know if it's working or not.
scoop
PostPosted: Sat Aug 11, 2012 4:32 am Up
the high speed fan kicks in when it reach 100c but the low speed fan never kicks in when at 90c or above, but it works when i turn on the a/c, could that be the resistor??
ahmed
usher
PostPosted: Sat Aug 11, 2012 10:44 am Up
sounds about right to me, mine used to do them temps untill i heat wrapped the manifold then it dropped by 5-10 deg
problems if your not happy could be thermostat, sure you could change tha for cheap enough
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
