Latest: Beduff1977
Overall: 17134
Online Now [546]:
Visitors: 545
Today: 207628
Total: 108142625
Forums › The Car › 206 Problems › rear wheel bearing
rear wheel bearing
kenzie
PostPosted: Sun Aug 19, 2012 4:01 am Up
my dad was follwing me the other day and said i have a wobble on the n/s rear of my car, so i jacked it up and i think it the wheel bearing is worn. is this an easy job or will be be best for a mechanic to do or does anyone no of a guide how to change the bearing
thanks guys
Red 206 GTi
Revenge is like a ghost. It takes over every man it touches. It's thirst cannot be quenched, until the last man standing has fallen. The world's men of action will look and wonder...how it came to this. You may be able to destroy me, but the beast will eventually come for you
PostPosted: Sun Aug 19, 2012 4:05 am Up
Discs or drums?
kenzie
PostPosted: Sun Aug 19, 2012 4:06 am Up
disc mate on a 1999 gti 138
Red 206 GTi
PostPosted: Sun Aug 19, 2012 5:35 am Up
not sure if you can just buy the bearing :/
gazza82
PostPosted: Sun Aug 19, 2012 7:09 am Up
You probably can, but then you'd need an hydraulic press to get the new one into the hub ... plus the fun of getting the old one out ...
This isn't the cheapest but shows a pic .. suggests you get the hub assembly, new hub nut and cover:
www.carparts4less.co.u...9fd&000370
You'll need a hub puller to get the old one off and it's highly likely the inner bearing race will stay on the stub axle .. and then you'll need an angle grinder to cut it away to the point when you can crack it so it comes off. (That's how I did one on my Alfa earlier this year).
PostPosted: Sun Aug 19, 2012 9:25 am Up
www.carparts4less.co.u...amp;000370
you got the parts number or size and dimension of just the bearing?
i never been able to find one. pug dealer only sell the complete hubs
gazza82
PostPosted: Wed Aug 22, 2012 3:51 am Up
No ... which is why I said probably ... what about checking something like the SKF website?
I think most garages take the easy option ... complete hub assembly ... less hassle, less time, ...
