Online Now [133]:
Visitors: 132
Today: 6271
Total: 104956668
Forums › The Car › 206 Problems › odometer lcd problem
rawills
PostPosted: Thu Aug 30, 2012 12:20 pm Up
Hi all. I am fairly new to peugeot's so any issue's with these 206's is going to be a learning curve.
My odometer has worked fine until yesterday, when i turn the ignition on but not start the engine it stay's 'STOP' fine, but once the engine is started there is no display at all.
I've done a bit of searching on here but as mentioned not clued up at all so i don't want to start pulling things apart unless someone suggest's something needs changing etc.
Any help would be great from checking the right fuse to ordering the right bulb (if its blown) lol
The car is a 2.0 d-turbo and i am guessing its preplexed?
Here is the status of the dash.
Ignition on but engine not running.
Engine running.
Who\'s coat is that jacket?
steveo1259
PostPosted: Thu Aug 30, 2012 2:05 pm Up
That's normal.
All the lights you are commenting on are warning lights and only light up when the ignition is on to show they are working.
They should not illuminate once the ignition is on unless something is broken.
Owner of 1.4 petrol 206
rawills
PostPosted: Thu Aug 30, 2012 5:11 pm Up
Hi steveo, the lights arent the problem its the "lcd" part as also in the topic Very Happy
Baiscly i cannot see the millage little lcd screen (in the mph part) where it displays "STOP" before the engine is started.
steveo1259
PostPosted: Thu Aug 30, 2012 6:39 pm Up
there's no screen there.Its just a cut out with a bulb behind it that lights up on ignition and stalling only
davecuk
PostPosted: Fri Aug 31, 2012 1:09 am Up
the display has a bulb behind it you have to remove the complete unit from dash to get to it. hope this helps
206 1.9 d silver
206boyracer
PostPosted: Fri Aug 31, 2012 1:34 am Up
The mileage screen is the one at the top which says 929.7 i would assume that it's been changed to counter mode. If you press the little knob on the bottom right it should display how many miles in total the car has done. Press it again to go back to trip counter and hold it in to reset your trip counter.
The stop you are referring to is a warning light. It just illuminates on startup to let you know the bilb works so if there is a problem it will come on.
206 GTI 138.
rawills
PostPosted: Fri Aug 31, 2012 4:55 am Up
ahh cheers guys glad you confirmed it, was almost sure i seen a lcd there but now i can stop worrying lol.
