Latest: tbafonso
Overall: 17130
Online Now [123]:
Visitors: 123
Today: 39852
Total: 104571625
Forums › The Car › 206 Problems › Starting issues
Starting issues
Tommy29
PostPosted: Thu Oct 04, 2012 4:16 pm Up
Hi, I'm new to this forum but I hope someone can help. My girlfriend has a 1.1 04 plate 'fever' and I'm in charge of maintanance! Its having some trouble starting, it cranks over for rather longer than it should, and it has reset all the time clocks and silly things back to 0 a few times once started? I'm not that good at explaining, but I'm better at answering! Any help is appreciated, cheers guys!
Dillon
PostPosted: Thu Oct 04, 2012 6:26 pm Up
Staff - Dillon
Check the battery, there sensitive to voltage drop are the mux pugs.
Junglingo
PostPosted: Fri Oct 05, 2012 3:07 am Up
Battery is on its way out
GTi 180 - Scorpion Exhaust
Tommy29
PostPosted: Fri Oct 05, 2012 2:52 pm Up
Okay thanks guys, I hadn't even thought of something as simple as the battery! I was waiting for an expensive issue haha!
bovine3737
PostPosted: Sun Oct 14, 2012 5:16 am Up
hi, this is my first time on a forum. just bought a 1400 206,2000 model when we first got the car it would run fine but sometimes cut out, went to start it this morning it wont tick over, starts ok and if you keep the revvs up it runs, but as soon as you take your foot off of the accelerator it cuts out. anybody got an idea?
thanks
PostPosted: Sun Oct 14, 2012 5:38 am Up
Check the battery with a voltmeter or go to a garage to have it checked before shelling out on a new one. There is a known issue with the earth cables running from the battery to the body and the gearbox. Check these as they can sometimes give the same symptoms as the battery going flat.
Thumb Up Also congratulations on putting all the details of the car in your first post. There are some members on here that still don't realise that there are so many variants of the 206. Thumb Up
bovine3737
PostPosted: Tue Oct 16, 2012 2:59 am Up
battery new disconected a plug at the top of the throttle body, car runs perfect now but has lack of power on hills, ive bin told it could be the map sensor that is causing the problem. Confused
