Latest: sparrowdclxvi
Overall: 17139
Online Now [120]:
Visitors: 119
Today: 18646
Total: 113259035
Forums › The Car › 206 Problems › Rear Axle Symptoms?
Rear Axle Symptoms?
A10PSW
PostPosted: Tue Oct 16, 2012 8:08 am Up
How do you know if the rear axle bearings are failing?
What are the symptoms?
Abzynthe
PostPosted: Tue Oct 16, 2012 8:47 am Up
East Area Rep - Abzynthe
I think a bit of camber is one symptom and also if the wheel doest sit central to the arch?
Im sure there are other symptoms aswell.
usher
PostPosted: Tue Oct 16, 2012 10:10 am Up
squeeking over bumps for the trailing arm bearings
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
garywck
PostPosted: Fri Nov 16, 2012 4:45 am Up
And the rear suspension will getting much more stiffer.
I am 206 S16 owner from Hong Kong. Nice to meet you.
sig removed due to size
Please read www.206info.co.uk/Foru...27931.html
ukskater01
PostPosted: Fri Nov 16, 2012 8:36 am Up
When parked pull on the rear wheels to see if there is play
