Latest: tbafonso
Overall: 17130
Online Now [321]:
Visitors: 320
Today: 10556
Total: 104200252
Forums › The Car › 206 Talk › Front Hub Nut ??mm
Front Hub Nut ??mm
Mounty
PostPosted: Tue Oct 23, 2012 4:10 pm Up
Anyone know what sized socket I need to remove hub nut on GTi?
Cheers
2001 206 Gti - Original & Unmolested
1994 Renault 5 - Production Car Trials
PostPosted: Tue Oct 23, 2012 4:47 pm Up
Could be 32 or 35mm
Mounty
PostPosted: Tue Oct 23, 2012 4:50 pm Up
Its not 32mm, bigger than that. 34mm been suggested on another thread....?
PostPosted: Tue Oct 23, 2012 5:37 pm Up
35mm
or you could just measure it..... isn't that easier and quicker?
Mounty
PostPosted: Tue Oct 30, 2012 5:10 pm Up
Measured it at 35mm - Bought a 35mm impact socket and used it with impact gun. Came straight off with the gun. Socket felt a little loose and still not sure its not a 34mm nut??
PostPosted: Tue Oct 30, 2012 5:16 pm Up
well if you measure it and it said 35 how can it be 34?
Mounty
PostPosted: Tue Oct 30, 2012 5:25 pm Up
Job to measure with a tape as shaft thru centre of nut prevents you from getting tape close to nut for measuring. 35mm fits but a little play so now thinking it may be 34mm. Didn't matter in end as impact gun removed in 2 secs without having to strap up hub to stop it spinning
DanT
PostPosted: Tue Oct 30, 2012 5:35 pm Up
Deffo a 35mm on my 180. 34 wasnt anywhere near fitting when i tried guessing first time lol.
PostPosted: Tue Oct 30, 2012 5:42 pm Up
it's all up to you whether you believe is 35mm or not Laughing
i use 35mm socket, Dan (above) agree with me, addaz (future master tech in pug dealership) also said 35mm, plus you did use 35mm socket to remove the nut
Mounty
PostPosted: Tue Oct 30, 2012 5:53 pm Up
No axe to grind, 35mm worked for me as i said, but it wasn't a tight fit. Just sayin
PostPosted: Tue Oct 30, 2012 5:55 pm Up
not surprise, either of mine is tight fit.
since they are not reusable i wouldn't worry too much
PostPosted: Wed Oct 31, 2012 10:31 am Up
Also means access to the Peugeot master tech forum Laughing
PostPosted: Wed Oct 31, 2012 1:28 pm Up
My Sealey socket is a 35mm..
PostPosted: Wed Oct 31, 2012 3:23 pm Up
Ahhh the site i cant access yet, one day <3
Thanks though mate, hopefully one day that will be the case Thumbs Up
