Latest: sparrowdclxvi
Overall: 17139
Online Now [183]:
Visitors: 182
Today: 24498
Total: 113396830
Forums › The Car › 206 Talk › What Bosch Battery? For GTi 138
PostPosted: Thu Oct 25, 2012 2:48 pm Up
I see ECP have a good discount on batterys at the moment. Which one do i need though?! 54 plate GTi.
DeadEyePaul
PostPosted: Fri Oct 26, 2012 2:18 am Up
Bosch s4 powers my v6 engine nicely same battery I used to start my 206 1.4 sport engine before the conversion
usher
PostPosted: Fri Oct 26, 2012 12:53 pm Up
think mine an s1 will check later
had a look on ebay they seam to recomend s3
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
iSamTz
PostPosted: Fri Oct 26, 2012 1:16 pm Up
Trade Rating: -1
ive got a s3 battery Smile there the one to get!
206 1.4 2002 - Project Car
BMW 116 2012 - Work car
Yamaha R1 - Race bike (snetterton, Cadwell)
PostPosted: Fri Oct 26, 2012 1:59 pm Up
I got an S3 on mine. Cheap enough. Just make sure you measure your old one and take the measurements to the shop as they sometimes get it wrong.
PostPosted: Fri Oct 26, 2012 3:54 pm Up
S5 ftw
usher
PostPosted: Fri Oct 26, 2012 4:36 pm Up
i ended up having to wedge a block of wood behind mine as its too small for the battery tray
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Sat Oct 27, 2012 2:29 am Up
Surely the top clamp would hold it in position?
PostPosted: Sat Oct 27, 2012 7:22 am Up
If its like my clamp, the plastic it bolts into gas snapped. I've replaced mine twice, not particularly over tightened.
