Posted: Thu Oct 25, 2012 2:48 pm |
I see ECP have a good discount on batterys at the moment. Which one do i need though?! 54 plate GTi.
Posted: Fri Oct 26, 2012 2:18 am |
Bosch s4 powers my v6 engine nicely same battery I used to start my 206 1.4 sport engine before the conversion
Posted: Fri Oct 26, 2012 12:53 pm |
think mine an s1 will check later
had a look on ebay they seam to recomend s3
Posted: Fri Oct 26, 2012 1:16 pm |
Trade Rating: -1
ive got a s3 battery there the one to get!
Posted: Fri Oct 26, 2012 1:59 pm |
I got an S3 on mine. Cheap enough. Just make sure you measure your old one and take the measurements to the shop as they sometimes get it wrong.
Posted: Fri Oct 26, 2012 3:54 pm |
S5 ftw
Posted: Fri Oct 26, 2012 4:36 pm |
i ended up having to wedge a block of wood behind mine as its too small for the battery tray
Posted: Sat Oct 27, 2012 2:29 am |
Surely the top clamp would hold it in position?
Posted: Sat Oct 27, 2012 7:22 am |
If its like my clamp, the plastic it bolts into gas snapped. I've replaced mine twice, not particularly over tightened.
