Posted: Sat Nov 10, 2012 2:47 pm |
On this graph, charge into the battery would be positive (ie greater than zero), discharge negative (less than zero). The amount of negative current gets less negative (more positive), ie less discharge, with time. Thats why it goes up!!
Depends on your perspective ![Very Happy Very Happy](images/smiles/icon_biggrin.gif)
| | ![](images/spacer.gif) |
Posted: Sat Nov 10, 2012 2:51 pm |
No graph is absolutely correct if you read the Y-scale.
Just saying because some people might have expected to see the line dropping after switch-off.
(which it does in value)
Posted: Sat Nov 10, 2012 2:52 pm |
Posted: Sat Nov 10, 2012 3:01 pm |
Just measured the quiescent state with more accuracy, it is 7mA.
Still working ![Razz Razz](images/smiles/icon_razz.gif)
Posted: Sat Nov 10, 2012 3:11 pm |
7mA is perfectly fine for quiescent current.
Your graph shows very well why battery should not be just disconnected without proper care or with ignition on.
Here it is again so it's visible on this page:
![](http://i875.photobucket.com/albums/ab313/V9977/Batterydischargeafterswitchoff.jpg~original)
Posted: Sat Nov 10, 2012 4:01 pm |
this post is probably one of the best post this year
Posted: Sat Nov 10, 2012 10:20 pm |
The battery disconnect procedure and the soft reboot both tell to wait 3 mins before messing with the rest of the procedure so it makes good sense when you read the graph....nice one.
it would be interesting to know what is being switched off at each noticeable change/drop on the graph?
