Latest: tbafonso
Overall: 17130
Online Now [231]:
Visitors: 231
Today: 39745
Total: 104394996
Forums › The Car › 206 Problems › 206 GTI 180 power steering problem?
boardinbob78
PostPosted: Tue Nov 20, 2012 3:27 pm Up
Just bought a gti 180 and noticed steering is fairly heavy at low speeds, i know this is to be expected of this car but steering is quite noisy and whiney when the power steering is in use.
Also noticed a sort of burning smell, not like oil but possibly the p/s fluid, anyway topped up the reservoir but problem persists.
Could the p/s pump be faulty or maybe a leak or low pressure in the system? Where do I begin to look for a problem?
broadblaster
PostPosted: Tue Nov 20, 2012 3:51 pm Up
i would think if it was a leak you would see the fluid dripping down.
first thing i would do is change the fluid as most people never do this and then see what its like.
as you say they are heavy on the 180's but should not make a whinny noise.
also what is the belt like ??? could that be slipping ???
on a back road playing
Dan-
PostPosted: Tue Nov 20, 2012 3:52 pm Up
dont remember mine being noisy but was fairly heavy at times, i was considering removing the pump when i got the car as i dont like the weightless of steering on some cars but was actually quite a nice weight as it was,
i would point it to either i faulty pump or loose belt?
Dan-
Damn you beat me Razz
broadblaster
PostPosted: Tue Nov 20, 2012 3:54 pm Up
lol lol sorry mate
boardinbob78
PostPosted: Tue Nov 20, 2012 3:55 pm Up
ok i'll check for leaks and belt in the morning, is the belt easily accessible, must be close to the ps reservoir i guess?
broadblaster
PostPosted: Tue Nov 20, 2012 3:58 pm Up
its not the best to get at mate but you should get to it it runs round the main pas pump and alternater.
Dan-
PostPosted: Tue Nov 20, 2012 4:00 pm Up
they should make power steering work up to say 2k revs so when parking it on and when moving its not!
only in rallying i would say you need the power assisted as it makes tight handbrake turns easier
Dan-
PostPosted: Tue Nov 20, 2012 4:01 pm Up
acces is abit tight, buts its far easier to get to than the timing belt Razz
boardinbob78
PostPosted: Wed Nov 21, 2012 4:29 am Up
Must have a leak somewhere because topped fluid up yesterday and seems low again today.
PostPosted: Wed Nov 21, 2012 6:16 am Up
Ever seen a rally car with PAS failure? They cant even keep it in a straight line because they cant make all the constant steering corrections.
PostPosted: Wed Nov 21, 2012 6:19 am Up
that is the most common reason for a PAS failure,
Dan-
PostPosted: Wed Nov 21, 2012 7:31 am Up
During the 2006 world rally when Chris Atkinson damaged his power steering, he lost around 4 mins, as he couldn't turn the car in
